Best Re-pop sheet metal
Old Sep 28, 2019 | 02:43 PM
Chumpy2112's Avatar
About to finally bite the bullet and attack the rust/rot on my 68 and I see Goodmark and Golden Star everywhere for my quarters. I think this stuff is all made in china......Is it any good? I would guess its much thinner than OEM. Anyone have opinions on this stuff?
Old Sep 28, 2019 | 03:46 PM
The partial quarters will all require a lot of metal finishing to look good. If you can find rust free original quarters from the desert southwest, you'll be money ahead to get them. In particular, if you get them cut beyond the stock spot welds, you can do a much better installation job. Of course, if all you need are small patches, get the partial quarters and cut what you need.
Old Sep 28, 2019 | 03:52 PM
Chumpy2112's Avatar
Thanks for the reply, I have been trying to locate some clean ones. Found a whole rear half in CT for 1600. might go that route.
Old Dec 12, 2019 | 11:57 AM
maddoctor's Avatar
repop panels
Look, all these repop panels are not as bad as everyone thinks. They are better than they were 10 even 5 years ago. The restoration shop doing the work on my car told me the panels I have for my car are very good and the companies producing them would not be in business if the panels were as bad as everyone says. They are all made high tech now and the steel is just as good as it was in the 60s or 70s. All the panels for our new cars are made in the same factories as these repops. Keep an open mind, do some research, talk to body shops, restoration centres and find the best ones you can.
Old Dec 12, 2019 | 12:31 PM
70cutty's Avatar
Beer Connoisseur
I believe AMD has the best quality repop panels.
On my Chevelle everything lined up properly without major problems. Same gauge as original and no major tweaking needed to fit. At first I bought Goodmark and ended up sending everything back.
People that complain about repop probably forgot that even GM replacement panels were not the greatest.
EDIT: AMD selection for Olds is limited.
Bernhard
Jan 3, 2017 06:52 PM
hilbily
Body work
Sep 9, 2014 08:54 PM
Macadoo
Body work
15
Sep 12, 2013 05:06 PM
rtanner68
Jul 19, 2010 04:32 PM
southcarolina803
Aug 6, 2008 06:04 PM
