anyone use fuzor panel adhesive?
Old May 15th, 2017 | 10:18 AM
dynamic63's Avatar
looking at no weld panel adhesives to put my new half quarter panel on my 63 88. never used them before but don't have the best welder so I figure on trying this. people say it is good but how do you clamp the overlap in the middle of the panel? or do you just hold it for a few mins?
Old May 15th, 2017 | 12:21 PM
m371961's Avatar
I have flanged, glue and countersunk rivets to attach. But I could hide it behind molding.
Old May 15th, 2017 | 01:17 PM
bccan's Avatar
Lord-Fuzor makes good products, the panel bonders you are working with come in different cure times. You should probabbly be using one that gives appx 2 hours just in case you run into trouble.
Usually clamped w/ very long vise grips w/ paint stick "bridges" to spread load, Tek screws or rivets would work as posted previously. The important thing is that you have sufficient material in an unbroken bead w/ no gaps, try not to smear it out of joint positioning panel and dont clamp it too tight - don't want to squeeze it all out of the seam. Always nice to have to have a helper when setting a panel of some size.
Old February 8th, 2019 | 11:56 AM
dynamic63's Avatar
thank you
Old February 8th, 2019 | 01:24 PM
So, did you use the panel adhesive? This thread is almost 2 years old now. I was going to suggest renting a welder instead. You wouldn't want to use so much bondo to cover up a seam where two panels are joined together.
rroth01
November 10th, 2014 08:20 AM
m1369d
Body work
February 15th, 2014 01:41 PM
Eddie Hansen
Body work
26
August 13th, 2012 09:41 AM
Ranzan
March 27th, 2010 05:20 PM
