71 Olds - problem with driver's side door
Old Aug 30, 2013 | 02:35 PM
rmsikorski66's Avatar
Unhappy 71 Olds - problem with driver's side door
Hi everyone. I need some help on this. I have a 71 Olds Cutlass Convertible. The driver's side door is giving me fits. When I close it, unless I really slam it hard. The door kind of "falls away" (slightly down and outwards) about a quarter of an inch. I'm not sure what the real problem is. If I slam the door hard, it stays closed properly. Door latch slipping? Or, perhaps it has some "play" or slop in it? Not really sure. The door doesn't appear to be out of alignment in any way. Thought? Thanks.
Old Aug 30, 2013 | 02:51 PM
72cutlassconv's Avatar
Check the latch on the door and make sure that it latches without binding. It could be that when the car got painted the striker was moved/adjusted (happened to me). Maybe you can take a few pics of that area so we can see what's going on.
Old Aug 30, 2013 | 03:09 PM
Or the hinges are out of alignment.
Old Aug 30, 2013 | 04:45 PM
at3reg98's Avatar
New 2 Olds
Open the door and lift up on it. If there's play and you can lift it up on the hinges, the pins are worn. Someone else can give you tips on how to redo those. In the meantime you might be able to adjust the striker, but you have to be very careful as I've heard of the door getting stuck closed!
Old Aug 31, 2013 | 08:57 AM
re: problem with driver's side door
I gave the situation a closer look and I think the door needs to be adjusted. As you can see by looking at the image, the door is sagging / or angled downward slightly. I think I need to fix this and then see if the problem goes away.
Old Aug 31, 2013 | 11:42 AM
You have two problems. First, your hinges are worn. Second, due to the worn hinges, I'm guessing your striker bolt is worn also. Step one is to replace the hinges (or at least the bushings and pins). Step two is to remove the striker bolt and align the hinges properly. Step three is to install and adjust a new striker bolt.
Old Aug 31, 2013 | 12:55 PM
jfb's Avatar
jfb
get the originals rebuilt the aftermarket ones sold are a nightmare to work with! I usually with a jack and wood can adjust a door but not those aftermarkets! I had a buddy with as much time as me in the trade give me a hand and it took reaaaal time to adjust them. they are made poorly wherever there made. use the virgin marks made ,for when you put back in the rebuilt originals buddy. I would also do a lot of homework on the aftermarkets being built now! if you want to go this route things could have changed in the last 7 years.
Old Nov 12, 2013 | 06:37 AM
The Bug Man's Avatar
Ditto. He nailed it
oldspackrat
Sep 29, 2014 01:35 PM
rmsikorski66
Sep 8, 2013 12:58 PM
pippy
Nov 7, 2007 07:00 AM
ztim
Mar 15, 2007 07:57 PM
