71 olds cutlass supreme dash/ windshield channel repair
Old Oct 28, 2020 | 06:20 PM
Jeffs71's Avatar
My Olds windshield was cracked after a tree limb fell . The glass installer noticed rust along the dash panel and below wiper trim panel, and advised me to seek a body shop to fix that area before he installed the new glass .
the shop can fabricate a new channel, but I suggested a new cowl grill panel like OPGI sells . Theres also rot along the dash top. Does anyone know where I could source a patch panel for the upper dash , or just have shop weld a new strip there ?
here's the area in question
the cowl grill panel i was looking at is this part
any suggestions appreciated
jeff
Old Oct 29, 2020 | 06:51 AM
Belden Speed sells the channel patch panels.
https://www.rustreplace.com/home/196...972-cutlass442
Old Oct 29, 2020 | 09:53 AM
Jeffs71's Avatar
Thanks Joe
sounds like a common rust area from east coast cars
Old Oct 29, 2020 | 09:55 AM
Originally Posted by Jeffs71
Thanks Joe
Sadly, it's a common rust area on all of them. The clips that hold the stainless trim scratch the paint when you install them, and the design of the trim traps leaves and debris which turns to mulch and attacks those scratches.
Old Oct 29, 2020 | 10:29 AM
ajr2820's Avatar
I thought Belden only made the top pieces. I bought a lower channel for a Chevelle and modified it. Here is the result.
Old Oct 29, 2020 | 10:34 AM
They've expanded their products. Check the link I provided. Now if we can only convince him to start making the piece at the bottom of the back window on the 68-72 cars.
Old Oct 29, 2020 | 12:11 PM
ajr2820's Avatar
Funny, this is all I see.
Old Oct 29, 2020 | 12:20 PM
Well, damn! I thought diagram this was showing the lower channel, but if you look closely, it's the top. DOH! Sorry about that.
Old Oct 29, 2020 | 12:47 PM
ajr2820's Avatar
Haha! No worries. I made the same mistake a while back when I was looking for the lower channel myself and ended up buying the Chevelle patch....took a little cutting, but worked well.
Old Oct 29, 2020 | 06:05 PM
Jeffs71's Avatar
I appreciate the info, I ended up ordering the opgi cowl top repair panel. Mines been eaten away on the edge of dash metal a few inches , but body shop says they can weld a strip along there, and the cowl section will make rebuilding the channel easier .
I was told about the Chevelle metal panels but seems like everything else this year is out of stock w a long lead time
Old Oct 29, 2020 | 06:08 PM
Jeffs71's Avatar
beautiful repair work !!! Did you reuse your Olds dash top then graft in the chevy piece? I'd love to blow mine apart, but haven't space or skills to do the work myself ...and our 4 yr old daughter keeps us busy lol
Old Oct 30, 2020 | 05:47 AM
ajr2820's Avatar
Yeah. I just grafted in the Chevy piece. Not a big deal. The curvature is the same. You just need to do some minor surgery on the piece to get it to fit right. The rust went further up the dash to where the speaker is, but there was enough meat to not have to cut too far. I cleaned that part up and used a small amount of bondo to smooth the area out.
Old Apr 23, 2021 | 09:36 PM
D1970442's Avatar
Getting ready to start a dash/cowl repair. I bought the top cowl and repair patch panel below but its not thick enough to cover all the rust on the Dash. Where did you find the chevelle dash repair panel or 69 cutlass dash repair panel? Many thanks!
Old May 17, 2021 | 10:20 PM
tkcutlass's Avatar
I have the same rot on my 69 looks like this might do the trick dash patch
Old May 20, 2021 | 09:04 AM
ajr2820's Avatar
That is what I used to repair mine. You just have to trim it up a bit to fit. Not a big deal. I was a total rookie when I did mine.
Old May 20, 2021 | 09:41 AM
lunaboy's Avatar
The Rocket Astronomer
i have this piece that goes up a little higher inside the windshield
, but as joe says rust from the clips even got this one a little .
Old Dec 27, 2024 | 07:01 PM
flameorange's Avatar
Great pics
Great pics first time I have seen this area even remotely intact 😆…👌
cheers
Ultra Tweaker
Apr 30, 2021 02:21 PM
bob klein
Feb 13, 2016 11:08 AM
2Olds4U
May 6, 2014 06:32 PM
alek72us
Body work
29
Jan 24, 2011 04:41 AM
jr711
Body work
Apr 21, 2009 10:48 AM
