3 piece plastic cowl screen set from OPG
Saw this set on Summit, claims its a replacement for factory original screens. Really? not just wire mesh? Has anyone installed this?
http://www.summitracing.com/parts/op...ake/oldsmobile
IMHO, I would use the factory chicken wire, as they will keep more debris out of your cowl (common rust area). Fusicks and Inline Tube has the reproduction wire mesh cowl screen, or buy used from someone here.
I like the very clean look of the snap in plastic covers. They look factory and IMO you avoid the tackiness of the chicken wire look. What was on these cars from the factory? When I got my 68 it had the chicken wire. I assumed someone had put it on because they couldn't find the correct cowl screens and it looked terrible. The plastic covers look professional and correct.
3 pc plastic cowl screen
I like that. They look correct, but they are wrong.
Putting the fuel pump in upside-down looks correct to Chebby guys.
Painting the accessory brackets silver looks correct to some people.
I've noticed that misusing and misspelling words looks correct to many people on the internet, as well.
Unfortunately, though all of these things may look correct, none are.
It's your car, you have the right to make it look as correct as you want to, but looking correct and being correct are two different things.
I figure they go with my custom W46 stripe, 455, tremec 5 speed, W30 fenderwells and my chevy brake pedal. I honestly thought someone had cut some door screen and put it on the car. That's how mine looked anyway. I checked and found out you guys are right. The back door screen is the correct piece for these cars. That's going to lose me some points at the olds nats. Damn.
This is wrong. I was tricked.
http://www.ebay.com/itm/68-69-70-71-...60418580381%26
Yours seem to lay flat though. Unless its just the angle of the picture. The ones from eBay are raised in spots.
My original chicken wires weren't fitting flat and were allowing all kinds of leaves into my cowl. And, I was tired of getting nasty cuts on my hands from the jagged edges. I replaced them with the plastic ones and they seem to fit perfect. While they aren't correct, neither are red plug wires, radial tires, aftermarket wheels, MSD or other electronic ignitions, Interstate Batteries and anything but Delco spark plugs, many of which are on my car. I paid about $40 from OPGI (yikes!) but they fit.
The back door screen is the correct piece for these cars. The plastic looks much better IMO. Dfire, you have a really bad set apparently. Mine snapped in and lay flat, nice. If you don't like the plastic, grab your back door screen and cut out a new one. It will look great!
http://www.lowes.com/cd_Repairing+an...ens_755594716_
I think no one should complain about using the plastic ones unless their car is 100% original itself, excluding things that must be replaced, like tires and plugs. Especially people who put in bigger engines, clone, badge, and put on lots of bling like chrome valve covers and cleaners and red fenderwells.
Edit: Most Chevies came with nothing up there.
amen . I had a set from 2004 and they fit like s--t! they were to small for the openings from opgi also maybe china has done a better job since then. I have since then used back door screen new of course though! I would trust almost zero parts from china or mexice but canada parts seem to be okay at times.
I replaced the adjustable bumper for the rear of the hood and got 3 cuts from that stupid wire mesh!
As soon as I can I will make an order for the plastic inserts!
I used to get them out of junk yards but.............. no reason to go to a junkyard now when you can have it shipped to your door step and you don't have to leave the computer chair or move hardly at all.
While the plastic does look a bit better than the screen, the large holes will allow big debris to fall in the cowl and help clog the drainage channels.
I would use the wire under the plastic somehow....
My guess is that the maker of them thought you would need extra clearance for the wiper linkage. Not sure how far it drops in, but with the wire no extra clearance was needed. Maybe other makes needed the extra clearance?
Nor Cal Andy
August 5th, 2013 03:31 PM
Indy_68_S
Brakes/Hydraulic Systems
January 2nd, 2011 09:23 AM
