1969 cowl hood?
Old Nov 25, 2012 | 06:08 PM
Cjs1969's Avatar
1969 cowl hood?
Anybody know where I can grab a cowl hood for a 1969 cutlass supreme? I added an Edelbrock RPM performer intake and am having Clearance issues.
Old Nov 25, 2012 | 06:12 PM
jims2000lt's Avatar
11.52 @116
Glasstech or VFN should be able to help.
Old Nov 25, 2012 | 06:43 PM
Cjs1969's Avatar
Do you how much higher the OAI hood is than stock?
Old Nov 29, 2012 | 06:58 PM
jfb's Avatar
jfb
if this helps use a dropped air cleaner i use one with a nitrous plate and a torker and have had no problems under a w-25 hood.
Old Nov 29, 2012 | 07:30 PM
Cjs1969's Avatar
I just ordered a regular air cleaner do you still think it will give me enough clearance?
Old Nov 30, 2012 | 12:06 PM
jfb's Avatar
jfb
check the total height ,intake, carb spacer if there,carb and air cleaner then if needed order a dropped air cleaner. that is why it is a dropped air cleaner base. use foam to check against the hood clearance with tape to hold the height. close lightly though.
Sampson
Jul 18, 2014 04:36 PM
georgiaboy697
Jul 2, 2010 09:23 PM
shockrebuild
May 12, 2010 10:52 AM
Nilsson
Sep 12, 2009 03:26 PM
87cutlass442
Jul 26, 2008 06:21 AM
