1967 Cutlass core support mounts
I'm working on a friends 67 Cutlass. He bought new bushings for the core support and Im wondering if they are correct. I looked in the CSM and it appears they are supposed to be two rubber pieces that sandwich the core support. Most parts catalogs list the core support bushing as a 64-72 application. It's been awhile since I took off the originals and I had to cut them off. Any help appreciated.
Matt
Matt
yes you should have two parts, lower mount with a steel insert and a rubber upper cushion. Most that I have seen ship with the cushion pushed on top of the mount so it may look like one piece, can you post a picture?
This looks different from what I remember on 70-72's but these photos are taken of two different 1967 Cutlass/442
The first shows a bolt with a large washer over a rubber doughnut under the hood on top of the core support
Under the core support is a square piece, rubber with a steel sleeve inside.
Then inside the frame is just a large washer with a nut on the bolt. I think on newer cars the rubber doughnut is inside the frame ear.
Here's what the hole in the frame looks like. This is a 1967 Cutlass frame and I know the 70-72 have a much larger hole here.
John
John
jensenracing77
Jan 25, 2018 04:16 PM
joesw31
May 31, 2015 04:17 PM
bronze66f85
Jun 9, 2014 03:50 PM
