1965 Cutlass front fender trim removal
Old Jun 4, 2017 | 11:17 AM
streetrod's Avatar
Does anybody know of an easy way to remove the front trim in front of the doors on the rear section of the front fenders on the Cutlass and 442 without removing the fender?
Old Jun 4, 2017 | 07:53 PM
oldolds88's Avatar
remove the bottom bolts and ineer w/h bolts and then pull it out gently, small hand would probably help also
Old Oct 28, 2018 | 08:53 PM
Likes2Laff's Avatar
I just saw this...I am trying to figure out how to remove the same molding on my 1965 98 Convertible
Old Oct 29, 2018 | 07:43 AM
therobski's Avatar
StreetRod on my 64 F-85 doors. There should be a small
screw at each end of the trim inside the door, remove those and the trim will slide off. 65 should be the same?
Old Oct 29, 2018 | 04:25 PM
Likes2Laff's Avatar
Different moldings. The moldings I'm talking about are rear of the front wheel,(forward of the door). The molding has 3 posts that go through the sheet metal. Front and back is accessible. Middle one is not.
Old Oct 29, 2018 | 06:01 PM
JATA's Avatar
As a previous member replied. 1. Remove bottom bolt on front fender 2. Remove rear inner fender bolts. Should be able to get your hand in to remove trim captive nuts.
Old Oct 29, 2018 | 06:05 PM
Likes2Laff's Avatar
In my first post, I should have said, "Great and Thanks"...cause that seemed to be the solution. Won't know until I try it this weekend.
Old Oct 30, 2018 | 05:28 AM
cherokeepeople's Avatar
and if you do take those bolts out make sure you don't lose the shims and make sure they go back in the same location.
FStanley
Body work
Mar 2, 2017 11:20 AM
costpenn
Dec 6, 2015 07:34 PM
FTW65W29
Jan 3, 2014 08:42 PM
spate51
Body work
Oct 17, 2011 12:19 PM
D.Mac
Nov 25, 2009 07:36 PM
