76 cutlass taillight gaskets
Hi all,
Anyone know if these are available? Not sure how the water is getting in. There's a gasket between the fiberglass tail housing and the body - but if that were bad water would get into the trunk. I had water a couple inches deep in the taillight itself - where the bulb goes. Had to remove the housing and pour out the water. Did some searching but don't see anything available. Assume I need to take the light assembly off the housing to see where the gasket might go, but any pointers on replacements? Do I need to just cut out a replacement from some generic gasket material?
Thanks!
Thanks!
