Hood raised drivers side
Old August 16th, 2018, 08:33 AM
Drsantos's Avatar
Is lowering the hood to match the fender height a simple adjustment or is the hinged bad?
Drsantos is offline
Old August 16th, 2018, 12:17 PM
It's a procedure. Get a helper.
Open the hood, and loosen the 3 bolts that hold the side of the hood spring assembly.
Have your helper push the hood UP firmly from the front.
While he's pushing up, tighten down the 3 bolts.
Hood should lower now with close to level. If necessary, repeat with more upward pressure.
If you only have 2 side hood spring bolts, use those 2. Same procedure.
Allan R is offline
Olds luvr
November 9th, 2013 09:19 AM
71boosted
April 17th, 2013 07:40 AM
archeryshooter
September 2nd, 2011 07:15 PM
defiant1
Body work
December 19th, 2010 06:58 PM
Quick Reply: Hood raised drivers side
