Hood raised drivers side
Old Aug 16, 2018 | 08:33 AM
Drsantos's Avatar
Is lowering the hood to match the fender height a simple adjustment or is the hinged bad?
Old Aug 16, 2018 | 12:17 PM
It's a procedure. Get a helper.
Open the hood, and loosen the 3 bolts that hold the side of the hood spring assembly.
Have your helper push the hood UP firmly from the front.
While he's pushing up, tighten down the 3 bolts.
Hood should lower now with close to level. If necessary, repeat with more upward pressure.
If you only have 2 side hood spring bolts, use those 2. Same procedure.
Olds luvr
Nov 9, 2013 09:19 AM
71boosted
Apr 17, 2013 07:40 AM
archeryshooter
Sep 2, 2011 07:15 PM
defiant1
Body work
Dec 19, 2010 06:58 PM
