O L D S M O B I L E letters barrel nuts?
Hey guys,
I'm getting ready to touch up the paint and do a good polish on the '71 Supreme. I want it to be shiney this summer
I've read a couple threads about how to remove the OLDSMOBILE letters from the trunk lid but the links to new barrel nuts are all dead (and about ten years old). I've been searching but I'm not even sure they're called "barrel nuts". Anyone have a link handy? They are the tubular design; not what I would call speed-nuts.
I've also been reading about the best ways to remove hood and rear window trim but my rear window trim is sealed to the vinyl top. Would I be opening a can of stinky worms if I try to remove that trim? There's a tiny bit of rust starting under than trim (yeah, I know, there's probably more but I'm not taking off the vinyl until next winter).
As always, thanks.
As always, thanks.
Au-Ve-Co calls them "tubular nuts". They are really snap-in friction fasteners. Here's the page from the Au-Ve-Co catalog.
Thanks for the link Joe. I'd actually seen that before but couldn't find it this time. I guess I'll need to just pull one of the letters and do some measuring.
Here's a pic. It's those little green jobs. sort of look like drywall anchors.
Will do.
No worries, Eric. Input is always welcome.
Good to know, Joe. They do look kind of plastic in the pic.
I'll post an update when I verify which ones fit.
Whichever is within arm's reach? That's how I work, at least
Acually, neither of the above links seem to be correct. 3/32" is too small and 3/16" is way too big. As I estimated, my posts measure 1/8th. But they're not a solid post; it's split with some sort of green glue inside. See pic.
The search continues.
Looks like the best bet here are the Auveco's. Anyone know the thickness of the sheet-metal of the deck lid?
My choices are .038-.044, .030-.036, .025-.035"
The .030-.036" picture looks to be the most similarly shaped tubular nuts with a retainer than compresses when tapped in rather than snapping back.
Okay, I'm going with the Auveco 2611. My holes measure a tiny bit more than 5/32" but near 3/16" and since they don't have any nuts that measure 64ths, these must be it.
I'll post back when I know for sure.
Last post (maybe):
The Dixied website wanted $10.72 for a box of 100. Fine. But they wanted $24 shipping? Not, I think, today.
This place wants $7.95 shipping, same price for a box of 100
https://autofastenersandclips.com/pr...36-panel-range
btrBill; if these fit, PM me your mailing address and I'll toss what you need in a small envelope.
Gear swap went well. I did everything but the actual shimming. I chickened out and took it to a pro, lol. It seems a little sluggish under 2500 RPM but that's when the torque converter kicks in.
Did you finally pick an engine from all those 455s you have hangin' around?
lol yes, yes I am going with the said running 1969 high compression 455 with c heads for now. I am going to pull intake as long as everything looks good I am going to stab it in . I got it from a mechanic shop that said he personally pulled it and I have no reason to think he would lie to me, as he had many to chose from lol
I am still planning on building my core block up but thinking of a drag car in my near future.
Tom442
Jul 25, 2011 02:46 PM
