What is this called?
Old January 10th, 2014, 09:08 PM
Quadracer's Avatar
The guy I bought the car off of said someone backed into the grill and tore it up. What is this support called. Hood latch support? Stone guard support? I've looked up several different things with no luck. Is it separate from the core support or is it part of it? I'm looking for one for a 72 if anyone has one or knows someone.
Quadracer is offline
Old January 10th, 2014, 09:19 PM
Posting a picture that we could see might be helpful.
Meanwhile, can you find it here?
MDchanic is offline
Old January 10th, 2014, 09:23 PM
Quadracer's Avatar
Old January 10th, 2014, 09:24 PM
OK! I posted and was wrong - that's part of the core support. You need to have it repaired by a good shop. It's not reproduced.
Allan R is offline
Old January 10th, 2014, 09:25 PM
Quadracer's Avatar
Sorry bout that. I moved the pic in my photobucket and it changed the link.
Old January 10th, 2014, 09:28 PM
Quadracer's Avatar
No, #39 is the part I'm needing and it hasn't been very easy to fine. I've seen some used core supports with it and some without.
Old January 10th, 2014, 09:38 PM
#39: Support, Hood Latch (welded), or
Hood latch support, '70-'72 F-85, #406862.
As the description states, this piece is welded to the core support, which explains some uncertainty as to whether it is all one piece or not.
MDchanic is offline
Old January 10th, 2014, 09:44 PM
39 is called the hood latch support and it's welded to the core support. That's what it says in the GM Parts manual. Group 8.080 Part 406862. Like I said earlier - I haven't seen it as a reproduced part.
Allan R is offline
Old January 10th, 2014, 09:45 PM
Dang you're quick Eric. I was doing a web search to see if I could find it anywhere. They're common repros for Chevy, but not Olds
Allan R is offline
Old January 10th, 2014, 09:46 PM
Quadracer's Avatar
Well crap, It sounds like I need to go on the hunt for a 72 core support then. Thanks for the help guys!
Old January 10th, 2014, 10:04 PM
Anytime. Seeing as you're in OH you're right next to 2 guys who can likely help you. Send one of these guys a PM, they both part out these cars. Most often the battery tray area is rusted out or the car has been hit on one side leaving that center brace very usable - just needs to be cut out. Those supports are the same for 71/72 Cutlass models, regardless of being coupe, sedan or wagon.
jensenracing77 - Eric - in Brazil, Indiana
oldspackrat - Scott - in Indianapolis, Indiana.
Allan R is offline
Old January 14th, 2014, 09:20 PM
Have a look at this 72 core support listed here on the site for 100.00. Maybe you could get him to cut out and send just the section you need?
Allan R is offline
Old January 14th, 2014, 10:04 PM
costpenn's Avatar
If we're talking about that support that the grilles bolt to and the hood release handle gives through, isn't it bolted to the core support with four bolts?
costpenn is offline
Old January 14th, 2014, 11:22 PM
70Post's Avatar
Joe is correct....it's just BOLTED to the core support, not welded.
70Post is online now
Old January 15th, 2014, 02:54 AM
Okay. Well, so much for accepting the Parts Manual's description...
MDchanic is offline
Old January 15th, 2014, 03:18 AM
Quadracer's Avatar
Thanks Allan! I sent the guy a PM asking if he'd just sell the center section. I'm waiting on a reply from another guy on here that's looking to see if he has one also.
Old January 15th, 2014, 04:04 AM
R-body_mopar's Avatar
Question
I'm not a bodyman, but your picture shows a piece that is just bent, not missing or rusted through. Seems to me a competent bodyshop could remove, straighten, and repair that piece to like new condition....
R-body_mopar is offline
Old January 15th, 2014, 04:33 AM
Quadracer's Avatar
Yes, it's bent and it's ripped. It's bad enough that I would have about the same amount of money having someone "try" to fix it and hope that everything lines back up and fits, as I would if I just found one and replaced it myself. The car is just going to be a daily driver but I don't want to fight with trying to get the stone guard and everything lined back up.
Old January 15th, 2014, 08:32 AM
Registered Luser
ent72olds's Avatar
As others have stated, it is bolted. They are hard to find, and usually are slightly bent when found used.
ent72olds is offline
Old January 15th, 2014, 08:53 AM
oldspackrat's Avatar
I have a couple good used ones, give me a call if the other guy does not get back to you?
Thanks.
Scott
c. 317-727-7041
oldspackrat is offline
Old January 15th, 2014, 09:02 AM
Professur's Avatar
CO comes through again.
Professur is offline
Old January 15th, 2014, 10:10 AM
Quadracer's Avatar
Thanks.
Scott
c. 317-727-7041
Thanks man! If I dont hear something after this weekend I will be getting a hold of you.
oldsmohaulic
December 18th, 2009 11:02 AM
Col Wickham
November 19th, 2009 04:58 PM
citcapp
October 8th, 2009 02:00 PM
thorpedo91
May 26th, 2009 05:43 PM
ztim
December 2nd, 2007 05:09 PM
Quick Reply: What is this called?
