Spacing the body up
Old Nov 19, 2010 | 05:15 PM
Cutlass&Co's Avatar
Spacing the body up
Is it a bad thing to space the body up a 1/4" to solve some clearence issues on the Cutlass?
The chassis was badly bent from transporting it to Australia.
I had the chassis straightend boxed and lazer checked and it's near perfect, 455ci and T56 angle is on the mark at 3 degrees but I just need a bit more room in a few places.
Old Nov 20, 2010 | 06:39 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'd go for it, but be sure to worry about door or fender gaps.
Old Nov 20, 2010 | 05:44 PM
Cutlass&Co's Avatar
Thanks J,
The tail shaft yoke on the gearbox is just a bit to close to the body crossmember for my liking, even if the gearbox sit well.
Old Nov 20, 2010 | 06:33 PM
compedgemarine's Avatar
if that is the only issue my first question would be how much space is there. it looks like almost 1/2". if so then that should be enough clearance. I have had cars where we cut the body crossmember and welded in a notch to make clearance. I would think that would be easier than raising the body.
Old Nov 23, 2010 | 02:47 AM
Cutlass&Co's Avatar
I've just got 1/4" and thats with a polly gearbox mount, so it won't be saging in a hurry.
socalrs
May 17, 2012 07:58 PM
MI455
Drivetrain/Differentials
Jun 14, 2010 08:14 PM
The Stickman
Jan 11, 2009 05:15 PM
65Delta88
Feb 27, 2004 04:08 AM
65Delta88
Nov 3, 2003 03:43 PM
