Separation between dashboard and body
Old Dec 21, 2024 | 04:29 PM
keyboard's Avatar
Question Separation between dashboard and body
Hi guys.
I have a question.
I have a separation between the dashboard and the body, I understand that this separation must be there, but I would like to know if there is some type of piece to cover that gap.
Thanks in advance.
Regards
Old Dec 21, 2024 | 05:49 PM
Loaded68W34's Avatar
When you put the kick panels and a-pillar covers in, they will fill the gap in that area. In the photo below, the a-pillar cover is not on yet, but you can see how the kick panel fills up the gap. The small gap still visible at the top is totally covered once the a-pillar covers go on.
Old Dec 28, 2024 | 06:05 AM
keyboard's Avatar
Thanks for the clarification.
From what I see, that "gap" is reduced, but there will always be a bit of separation between the body and the dashboard.
The interior of your olds looks spectacular, I congratulate you. Where did you buy the floor covering? It looks spectacular, I see that she is even wearing the skirt on the light change button.
Old Jan 9, 2025 | 12:11 PM
keyboard's Avatar
Cuando coloques los paneles de protección y las cubiertas del pilar A, rellenarán el espacio en esa zona. En la foto de abajo, la cubierta del pilar A aún no está colocada, pero puedes ver cómo el panel de protección rellena el espacio. El pequeño espacio que aún se ve en la parte superior queda totalmente cubierto una vez que se colocan las cubiertas del pilar A.
Hi sir.
Where did you buy the carpet?
Who is the manufacturer?
Thanks.
Regards
Old Jan 9, 2025 | 02:49 PM
The carpet is from ACC. I bought it on eBay.
Old Jan 12, 2025 | 01:30 PM
keyboard's Avatar
Thanks.
Two questions:
Did the carpet come with the cuts already made for the components?
Did the light button skirt also come installed in the carpet?
I have seen this one, from the same brand, ACC, but I am not sure if it is the same as yours: https://www.rockauto.com/es/moreinfo...ce=1-A1168-0-1
Old Jan 12, 2025 | 05:43 PM
Looks like the link posted is for essex or cutpile. My carpet is the factory style 80/20 loop. The carpet does not come cut out for any components and the dimmer switch gromet is simply included in the box. You trim it to fit when you install it.
wills30
Dec 15, 2024 03:13 PM
Navyman53
Body work
Apr 13, 2022 09:07 PM
brandon reynolds
Jul 23, 2019 04:12 PM
raw442
Sep 30, 2012 01:57 PM
nukesec1
Sep 19, 2009 06:56 AM
