Removing windows and doors 69 Cutlass
Old August 14th, 2015 | 01:29 PM
blunce's Avatar
Hey guys, I'm working on stripping down the body for a frame off.
The doors seem to be really well lined up as they are. Is there a way, or reason, to mark where the hinges are that would survive blasting, or is it best to just start anew on lining up the doors once everything goes back together?
Same question for windows.
Old August 14th, 2015 | 03:41 PM
The best way to ensure that the hinges go back the same way is to drill a couple of 1/8" holes through the hinge and into the door or door jamb. When reassembling, use pins or drill bits to line them back up.
Of course, after doing this I STILL have to readjust the doors...
Old August 15th, 2015 | 10:56 AM
blunce's Avatar
That's a good idea Joe, thanks. Think I may just start from scratch later on though, the more I think about it
Old August 15th, 2015 | 01:53 PM
To clean up the door and jambs properly there's really no way of not removing all the bolts that hold it in place. You could also deep scratch the jamb areas and door contact outlines to identify where the start point would be to getting them relocated (which is what Fisher recommends).
Any time I've replaced doors I basically had to dedicate at least an hour of time to alignment to get them just right. It's a bit harder on a 2 door than a 4 door because of the weight and length of the door. Use a door cradle (or anything that helps support the door at the far end) when making your adjustments. Do you have a Fisher manual? They list the tolerances in one area, and the Removal and Installation in another. I found the required information on page 6-39 of my 72 FBW manual - it should be identical for 69.
Old November 27th, 2015 | 08:56 PM
Carsick's Avatar
I'm curious which method u ended up using to mark and re install the doors. I'm in the same boat. my doors fit and shut nicely and Im not looking forward to re hanging them especially since I don't have someone to help. I like the idea of drilling out a couple in the hinge plate and using a couple drill bits to get them relocated. I already have the door glass out so I'm hoping a floor jack and a prayer or two will be enough to get them reinstalled with out fkg up the paint anywhere.
The rear quarter windows came out pretty easily. If you still need help removing them I have the factory service manual amd the fisher body manual.
*On a side note/random question. My 442 is a sports coupe (post) so it has the full door frame and door vent window. My question is how hard would it be to put a one piece window glass in the door to delete the vent window? My guess is that a regular coupe door glass would work if it was cut down a bit to compensate for the door frame. I think it would look really good not having the vent window and would give it a subtle custom look....
71cutlass350
March 18th, 2013 11:42 AM
halfmoontrail
February 22nd, 2013 12:14 PM
msco123
August 2nd, 2009 07:13 AM
rustycarr
March 7th, 2007 06:24 AM
DJMatthews
December 30th, 2006 07:38 PM
Quick Reply: Removing windows and doors 69 Cutlass
