newbie needs convertible top help
Old Nov 14, 2015 | 03:46 AM
mkenny's Avatar
70 cutlass supreme, replacing the convertible top. Trying to do it myself, but had no old top to look at and take measurements from. The car came with a replacement top only, I will be reusing the old rear glass window and replacing the pads too. So far all is going pretty well and I will post some pics when I can. Question is, the new top has two folds of material hanging down from each side. Do these folds get attached to the metal frame UNDER the weatherstipping or in some other way??? Any help on this would be appreciated. Also, anybody know where I can get a black wire-on as the new top did not come with one. thanks again,
Old Nov 14, 2015 | 07:43 AM
mrolds69's Avatar
Right...you need to remove the seals on the frame sides and the material goes under there at the front of the front windows and qtr windows. Many suppliers like Convertible Top Specialists sell the wire-on. Some are smooth vinyl and some match the top material.
Old Nov 14, 2015 | 10:53 AM
mkenny's Avatar
Thanks for the reply. That's what I was afraid of. I used weatherstripping adhesive to put the new seals in. Hopefully they come out easily. Live and learn I guess...
Old Nov 14, 2015 | 07:13 PM
mrolds69's Avatar
When you put them back on, you only glue the top, not the weatherstrip seals.
Old Nov 14, 2015 | 07:23 PM
Instead of weather strip adhesive I used black silicone between the seals and the top frame. I figured it would seal up better to keep the rain out. When I pulled the the top off several years back the seals came off easily.
quazy
Sep 23, 2015 10:32 PM
billmerbach
May 16, 2014 11:39 AM
64starfireme
Apr 11, 2009 06:40 AM
72greensupreme
Site Help
Mar 24, 2009 05:59 AM
DinkyDow
Sep 1, 2006 05:02 AM
