Medium reducer with slow hardner
Old Mar 18, 2023 | 10:25 AM
hinz57's Avatar
I ran out of slow reducer. I'm using Tamco Glamour clear coat that calls for 4:1:1 mixing ratio. I have some touch ups and small parts to paint. Can I use Medium reducer with a slow hardner (activator) in mixing the clear coat? Tried to google this issue but didn't come up with anything. Temp here today will be 65 degrees outside. Garage temp I expect to be about 70.
Old Mar 18, 2023 | 04:11 PM
hinz57's Avatar
I found my answer:
Match Reducers and Activators
Of course, not all clear coats are as thin as you would like straight out of the can. Adding a reducer to the mix can help thin them out. However, you’ve got to make sure that your activator matches the reducer. Slow reducers should be used with slow activators, and so on. Everything evaporates appropriately that way.
Old Mar 18, 2023 | 05:41 PM
Makes sense. Thanks for sharing what you found.
Rallye469
Feb 12, 2022 05:05 PM
Cutlass Fan
Paint
Nov 16, 2020 07:54 PM
Rustbucket2
Paint
20
Jul 25, 2019 08:08 PM
brown7373
Paint
Apr 6, 2013 01:49 PM
redvettemike
Paint
May 3, 2010 02:57 AM
