Glass Setting Tape to re-attach molding to quarter window?
Old Nov 19, 2009 | 03:37 PM
stlbluesbrother's Avatar
Question Glass Setting Tape to re-attach molding to quarter window?
I'm in the process of re-attaching chrome molding to the quarter window on my convertible and at a cross road as to the right product to use.
The Fisher Body manual mentions using either a "medium-bodied sealer or body caulking compound .... to provide either a watertight seal or for anti-rattle measures". What 'off the shelf' sealer has anyone used with lasting results? I have Weatherstrip adhesive, but i dont' think it's the same thing.
In another forum thread (https://classicoldsmobile.com/forums...m-removed.html) a process was outlined by Doug69Cutlass where glass setting tape is installed on the edge of the glass and then the trim channel is pressed over it. Anyone else use this with success? And if so, what thickness of tape was applied? Thanks in advance.
Old Nov 19, 2009 | 03:57 PM
Oldsmaniac's Avatar
My limited experience with this was on the front vent window on my 66 Delta. It was suggested I use black silicone and when it dried you trim and scrape it off the glass where it oozed....Result was ok, pretty good actually, but on real close inspection it did not look factory. I used the glass setting tape on the rear quarter window. It is rather tough to hammer/press the glass and chrome together with the tape on the glass. I was successful but it was hairy. I think you would use pretty thin tape. I believe there is a special tool for this process and perhaps a (friendly) old glass shop or trim shop may have one that you could use are let them put the molding on for you.
Old Nov 20, 2009 | 02:17 AM
Yellowstatue's Avatar
I just read somewhere that you are supposed to oil the channel before you put the tape in and the oil helps to set the tape after because it causes it to swell...
Old Nov 23, 2009 | 08:56 AM
Thanks for the info guys. I just ordered some 3/64 thickness tape. Hopefully, the fit will be snug and not loose or too tight.
RandyS
Aug 17, 2015 07:48 AM
jeffsims
Body work
Jun 4, 2014 05:16 PM
jensenracing77
Mar 2, 2014 08:55 AM
wisniows
Jan 12, 2014 09:30 PM
Gearhead442
Dec 5, 2012 02:33 PM
