Cowl/water dam replacement help
Old Feb 8, 2022 | 04:45 PM
HarrySlother's Avatar
I'm sick of opening my door to 2 inches of water everytime it rains so I want to get this out of the way, it's like the last panel that's rotted on my car. I was planning on replacing the top middle section that has the windshield wiper motor in it and where the water runs down to the fenders. Any guides on this? Do I have to remove the front section of the firewall or does it slide behind that? Any pictures of it?. Tac weld spots?
72 fastback
Old Feb 8, 2022 | 06:32 PM
2blu442's Avatar
I'm not sure the area your describing. Is this under the cowl screen? Can you post a picture of the area on your car? And what year & model of car are you working on?
Old Feb 8, 2022 | 06:56 PM
Link to replacement part
it's the under the screens, the wiper motor arms are in the valley, the rain water runs down the sides and down the fender.
Old Feb 8, 2022 | 07:27 PM
Yeah, that little tidbit of informaton may actaully be useful in order to provide any information to resolve the issue.
Old Feb 8, 2022 | 07:37 PM
Yellowstatue's Avatar
Could it also be, the water seal is not in place around the kick panel where it goes into the cowl side opening?
Old Feb 9, 2022 | 05:10 AM
The kick panel with the vent? That's not where the waters coming I deleted it. I sent the part thats rotted on my car
allyolds68's Avatar
If the base of the windshield is rusted through the water will run into the driver's compartment. I had already patched the area below the dash metal in this pic but if yours was Swiss cheese like mine was then water can run right in behind the dash. The area inside the cowl where the wiper transmission is mounted doesn't usually have a lot of rust. Usually they rust at the bottom on each side of the cowl. You also have to make sure the cowl can drain at each side. If there's crap in there plugging it up the water can make it's way into the cabin too
The lower cowl has to drain into the rocker panels. If the rocker panel drains are plugged up that can force water into the cabin as well. You can see how the lower cowl was rusted out in this pic. It's from crap building up in the lower cowl, retaining moisture and then rusting. The outside of mine was rusted as well
Old Feb 23, 2022 | 07:03 AM
I've had the front end off and windshield out and fixed everything that was accessible. The area inside the cowl has big holes in and I've tried using fiberglass as a temporarily solution but there's still small holes. I know the part I sent is what I need replaced, I just want to know if anyone's done it before or if there's information on it
Hairy Olds
Dec 17, 2021 06:05 PM
fiebs442
Body work
Jan 26, 2021 07:00 PM
Greg Rogers
Aug 15, 2018 07:14 PM
nightmare
Nov 4, 2011 05:30 AM
Oldsmofjord
Jul 30, 2007 04:58 AM
