71 gold engine paint
Old Nov 18, 2018 | 12:55 PM
tv442's Avatar
Hi,
well,any retail stores sell gold engine paint?
i just went to NAPA and struck out.
Thanks, Tim
Old Nov 18, 2018 | 02:04 PM
Dave26's Avatar
Advance Auto
Old Nov 18, 2018 | 02:12 PM
tv442's Avatar
Paint
thanks. I will check. Is it called olds 350 gold?
tim
Old Nov 18, 2018 | 03:39 PM
patshotrods's Avatar
Pat
Tim,
Advance Auto Parts and Car Quest carry it. It is Dupli-Color DE 1604 Universal Gold. I had to get some, I have to put a water pump on my Cutlass.
Thanks,
Old Nov 18, 2018 | 05:14 PM
Dave26's Avatar
This is what the Advance Auto stores near by me carry.
Old Nov 18, 2018 | 08:27 PM
bigrbandit's Avatar
72 Cutlass Ponca City OK
I will second on the DE1604 universal gold. It looks great. I would recommend that you use a light primer or hit your parts with silver first, or you will need a lot of light coats to get it to cover well.
Old Nov 19, 2018 | 05:57 AM
cdrod's Avatar
Rodney
Tim:
I used the VHT SP404 gold paint on my engine - see pic. I think it's a little brighter than the OEM color but looks good. I recommend applying several light coats as it runs easily and you'll be tempted to lay it on thick trying to cover the rough surface of the block. On my aluminum heads I scuffed the smooth surfaces with 320 grit paper to give the paint something to bite on to. I wiped everything down with lacquer thinner before spraying the paint. I hope this helps!
Rodney
Old Nov 19, 2018 | 02:19 PM
RetroRanger's Avatar
72 Olds CS
that looks real nice rod
Old Nov 19, 2018 | 02:27 PM
tv442's Avatar
Paint
hi again,
well, I ordered two cans of duplicolor universal gold from NAPA. I will try that soon.
Thanks for your tips and advice.
Rodney nice work on your engine!!
Tim
tva442
May 27, 2019 06:06 PM
mais18
Dec 3, 2018 08:38 AM
FuturamicOldsmobile
Nov 21, 2018 09:40 PM
rktolds
Nov 10, 2018 10:14 AM
brandon reynolds
Mar 30, 2018 02:02 PM
