71-72 Rear Decklid Emblem Installation
Old Dec 20, 2011 | 12:46 PM
HWYSTR455's Avatar
New repop decklid, and need to install the '4-4-2' emblems on it. Already painted car! Doh! Not sure why the body guy didn't do it, but oh well.
So, they go in an area that's blind from the inside, so no way to attach the speed nuts. So what's the secret? Adhesive?
Any insight here would be very appreciated!
Old Dec 20, 2011 | 01:22 PM
Emreozd's Avatar
great question! I'm curious too, since i'm gonna repaint the body and install the ambles someone please respond! over!
Old Dec 20, 2011 | 01:29 PM
svnt442's Avatar
They just push in.
I know this isn't the best pic, but you get the idea.
Old Dec 20, 2011 | 04:50 PM
HWYSTR455's Avatar
Oh! Really!?! Ok, I get it! Where do you find those nifty little items!?!
Old Dec 20, 2011 | 05:50 PM
svnt442's Avatar
They are part of the emblems.
Old Dec 20, 2011 | 08:40 PM
If you didn't get them as part of your emblems, they are called "barrel clips".
Available in different sizes. You can probably pick them up at local body shop supply.
This website has pics on pg 12 of their catalogue if you're interested. http://www.henrysautomotivewarehouse.com/2011_web.pdf
Old Dec 21, 2011 | 05:14 AM
HWYSTR455's Avatar
Hm, makes me wonder if the emblems with the barrel clips were used on a fender. I may just buy a new emblem with the clips.
And positioning the emblem(s) on the decklid? Any tips there?
Old Dec 21, 2011 | 09:13 AM
How completely ironic. I thought, Look it up in the Assembly Manual. So I did. The AM has all the piercings for the fenders, hoods but not the rear decks. I think this might be in the 442 by the Number restoration guide. Maybe someone who has a copy can check.
The other thing you do is get someone to pull their numbers and shoot a pic of the drilling so you'd have a template. A photo with measurements would be helpful?
Old Dec 21, 2011 | 04:49 PM
72w442's Avatar
72 442 Conv Viking Blue
I just cut the studs off of my emblems, then to help align them, I taped a paint stick just below them so the bottoms of the emblems could rest evenly on it, I then just put a few dabs of import gray gasket sealer on them, this way I could position them perfectly and did not have to drill any holes. Now no worries of water getting in there and will never rust.
https://classicoldsmobile.com/forums...1&d=1324514950
Old Dec 21, 2011 | 05:30 PM
Beob's Avatar
This is what I did and it worked real well. I got a piece of cardboard and poked the emblem pins through. Trying to keep them level and evenly spaced. Once they are pefectly lined up, pull them out and thats the template. I then taped it to car used a center punch then drilled. You will still measurements for exact placement. I also used the push in barrel clips on the lid and fenders
Old Dec 21, 2011 | 07:53 PM
69HO43's Avatar
Fender 442 and any nose numbers (69-70) use speed nuts on the back. As mentioned, barrel clips on the trunklid.
I like the adhesive trick, but I'm not sure about using globs of glue. I migh trim some thick 3M emblem tape to fit in the hollows of the emblem so you can't see the tape from the outside. Never tried it, though.
Remember when you do the 4's on 70-73, there is VERY little space between the two 4s. If I recall correctly, the 69's had a bit more gap back on the trunk, but it's been so long since I had one I don't recall for sure. And be very careful to ensure the numbers are perfectly aligned. It's just a pet peeve of mine to see haphazard emblem placement. There's bigger fish to fry in life than to worry about number spacing, but it still bugs me when I see a nice resto cheapened by misaligned numbers. To me, that stands out like a sore thumb.
Next time I go out to the shop I'll try to remember to pop the numbers off the trunk and make a "template" of sorts from a hardtop. I might be wrong, but I believe the the convertible lid placement is a tad bit different than hard top.
Old Jan 19, 2012 | 01:03 PM
HWYSTR455's Avatar
Allen R - Which clips are they on page 12 of your post?
I called Fusick's and ordered some clips they sell with their' emblems. They look different than some of the ones I've seen, guess they will work?
Question is, what size holes do I drill?
Old Jan 19, 2012 | 02:57 PM
What I'd do is try a test on a piece of old sheet metal. You know what size the stud is. Drill a slightly oversize one in metal and get the barrel nut to 'just snug'. None of the aftermarket companies give you anything in writing about this.
The sizes listed on P12 of that catalogue tell you what size the inside hole is (the stud) and what size to drill for it to fit.
Old Oct 14, 2012 | 07:46 PM
costpenn's Avatar
Hello All,
Going to pick up my car (72 442 vert) tomorrow, and just realized I had never given my painter a template for the trunk numeral mounting. Does anyone have either a template or some good pics with dimensions of where to drill the holes? I'd like to use the OE style mounting technique. (Hopefully 70POST is somewhere online)
Old Oct 14, 2012 | 08:41 PM
The template for drilling the numbers on the fender is in the 72 Assembly manual. I think the overall numbering is in the Fisher Body Manual.
Old Oct 15, 2012 | 05:23 AM
costpenn's Avatar
Anyone else on the trunk emblem placement? Any up close photos? Help - gotta go to pick it up in a few hours!!!
Old Oct 15, 2012 | 08:20 AM
emblems
Will these help? This is an original 72 442 in original paint.
Old Oct 15, 2012 | 08:47 AM
costpenn's Avatar
Thanks again Allan - I'll have a Moosehead while I'm picking it up this afternnoon in your honor.
What an absolutely beautiful day it is down here in Dallas - perfect for bringing it all back home.
Old Oct 31, 2012 | 02:53 PM
m455sx's Avatar
Olds Nut
hey allan make an etching of your deck lid and sell it to any one that needs it...like me.... lol
Old Oct 31, 2012 | 04:33 PM
61reoldsman's Avatar
Have a look at Napa they have a section with all these little items that you need to put you car together >I picked some barrel nuts up for Shane(Oldzzy) and they are exact ones that came off his trunk emblem (.032 )even said on it .They also have all the nuts and bolts that you could ever need .They also come in nice little baggies !The plastic ones that Fusick's sell are not useable if you have the original holes drilled from GM they are too big.
Old Nov 1, 2012 | 07:29 PM
??? my deck lid is for a 72 Cutlass S. Not compatible with a 70 CS. Different profile?
Were you referring to the trunk emblem? I ran across a member here about 2 weeks ago (????who???) and he has an NOS deck lid rocket he wants 100.00 for.
Bansheeman6100
Feb 3, 2015 06:37 AM
leroycjr
Jun 3, 2014 11:50 AM
therobski
Body work
Nov 6, 2012 05:53 AM
vette442
Jun 8, 2009 11:14 AM
