68 vs 69 fender bading cutlass s
Old Mar 13, 2026 | 06:58 AM
Al Curtis's Avatar
So I replaced my front fenders on my 69 cutlass convertible( so its a cutlass S.), with fenders off of a 68. - not sure what model. Now that she is painted i am puting all the trim back on, and i seem to have extra scripts/badging. Anybody have a good reference as to the badging between years- I also have two small mounting holes above the left rear side marker- on an aftermarket quarter replacement-
Old Mar 13, 2026 | 07:46 AM
allyolds68's Avatar
The Fusick catalog is a good resource to tell what's the same & different from 68-69
From the Fusick catalog and my (getting old) memory:
Hood "S" emblem is different
Trunk "Cutlass" script is different
"Cutlass" Fender Script is the same
"Oldsmobile" hood script is the same
Convertible "S" Trunk Rocket emblem is different but I don't remember what's different (the 68 Cutlass S convertible rocket emblem isn't reproduced, I don't think the 69 is either)
Fender S emblem should be the same
I'm not sure what extra hole's you're referring to.
The rear quarter marker lights are different from 68 to 69. 68 has a left and right, 69's are the same.
There's a single round hole at the rear of the 1/4 panel for the last trim connection fastener. Is that what you mean?
FWIW 68 hinges on a 69 hood are going to take some work to fit (hood bolt spacing is slightly different) and your head is going to hate you
Old Mar 13, 2026 | 10:17 AM
Al Curtis's Avatar
yup
Thanks -too true- yes i had to add the holes on the fender for the hood- 2 hole mouning on the 68, 3 holes on the 69-, as well as fill the old holes on the fender wheel arch, where the 68 molding was, and drill new ones for the peak molding LOL- caught the tooth a few times on the noggin already. Here is a picture of the holes on the
Old Mar 13, 2026 | 11:29 AM
allyolds68's Avatar
Those holes aren't original. I can't imagine what someone added them for.
On the wheel arch, if you're referring to the wheel opening molding, those were an option on the Cutlass S in 68 & 69, they were standard on the 442. There were other wheel arch trim configurations for the Cutlass Supreme and an optional F85 as well that are in a different location than the S/442. The S/442 opening trim fastened to the inside of the wheel opening, the other were holes in the side of the fender arch
.......as well as fill the old holes on the fender wheel arch, where the 68 molding was, and drill new ones for the peak molding......
69wmachine
Body work
Jun 2, 2023 02:52 AM
junior supercar
Nov 22, 2014 02:18 PM
