67 Cutlass windshield molding studs help
The 1967 Cutlass Supreme I bought has a new windshield,which is great. However, it looks like the PO removed all the studs for the molding clip studs. Does this make sense? Is it possible a new frame was used and they failed to notice the studs were not there? I don't see any way to get the studs put back.
Any thoughts from the group?
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Those pins rust and fall off. The best thing to do is to have new ones welded on. This is sometimes not doable due to circumstnces. I found the correct headed screw type replacements on ebay. It will be difficult to install them with the glass in.
Alex72cutty
October 9th, 2012 12:18 AM
