1972 rear Quarter skins vs Cutout
Does anyone have experience with rear quarter skins? The quarters on my 2 are shot and I'm debating on purchasing skins on Ebay or having the damaged metal cut out and replaced. What's the best way to go?
Link to skins:
http://www.ebay.com/itm/1970-1972-Cu...208d9c&vxp=mtr
Link to skins:
IMO, you're going to have metal cut out either way you go. I'd try to go with the least amount of cutting possible. How much of the quarter panel needs replacing will be the determining factor on going with patch panel or full skins. Also keep in mind that if the inside metal pieces (floor drops and inner/outer wheel housings) are rotted, it's a lot more work than just the outer skin.
Can you post pics of the damaged areas?
Those panels you posted the link for? Just for skins you can get them for a lot less money.
ratified442
November 5th, 2014 09:49 AM
