1969 cutlass lug nut stud problem...
Old September 18th, 2010, 02:01 PM
69CuTlass S's Avatar
hi! i need to know how to take a lug nut stud of my car its the passenger rear.
69CuTlass S is offline
Old September 18th, 2010, 02:38 PM
They are pressed into the axle flange. The dealerships had a special tool that looked like a C-clamp to allow you to remove the stud with the axle shaft in place. You can try using a big C-clamp with a socket on the back to provide clearance for the old stud to be pushed into. Failing that, the axle needs to come out and be put in a press.
If you do get it out without pulling the axle, install the new stud and again use a stack of washers or a section of pipe and pull the new stud into place with the lug nut. Otherwise, just use the press to put the new one in also. Whatever you do, do not just hammer on the axle flange. That's a good way to bend it.
joe_padavano is offline
ezman604
September 1st, 2015 03:09 PM
w-30dreamin
October 14th, 2014 08:51 PM
EightballZ
March 24th, 2014 05:03 PM
71_Olds
Wheels and Tires
December 26th, 2011 10:41 AM
yeahbuddy
Wheels and Tires
August 26th, 2010 09:38 PM
Quick Reply: 1969 cutlass lug nut stud problem...
