1967 442 4 speed
Old Oct 27, 2021 | 10:08 AM
Bills67's Avatar
1967 442 4 speed
can any one tell me what (correct) position the trunk key should be in on my 1967 442? mine is parallel to the ground. Also, is it better to remove front and back window to do the headliner and package tray?
I just brought the car home from paint shop 10/26/21!!
trunk lock position
Old Oct 27, 2021 | 10:19 AM
66SportCoupe's Avatar
Should be perpendicular to ground and the teeth go down.
Old Oct 27, 2021 | 10:40 AM
Bills67's Avatar
that's what I thought, because my 1967 Caprice is perpendicular! Thankyou very much for the info!!
Old Oct 27, 2021 | 12:28 PM
Rallye469's Avatar
Looks gorgeous.
And I've had no trouble getting the package tray and headliner in with the glass installed.
-peter
Old Oct 27, 2021 | 02:10 PM
Does the lock cylinder turn back to the vertical position with the key in it? If it does, your return spring on the back of the lock cylinder may be broken.
Old Oct 28, 2021 | 10:08 AM
nicks1966's Avatar
You can't put the lock cylinder in wrong unless the stamping in the deck lid is damaged. In the picture below notice the two large cutouts and the two small offset ones. this only allows the lock cylinder to go in correctly one way.
not2old
Jun 25, 2021 08:02 AM
MagicMan
May 2, 2021 07:44 AM
not2old
Jul 8, 2019 05:45 PM
not2old
May 22, 2018 06:37 PM
