detonation!!
Old Jul 25, 2015 | 12:21 PM
biggus's Avatar
detonation!!
Had my 455 set at 9° with the vacume advance disconnected and it detonated and rattled when I shut it off, so I backed it down to 7° and it's still doing it. Any ideas? Running Ca gas,91 octane, unplugged the advance 850 RPM with a stock style electronic distributer and I can't drive it for fear I'll kill it. Would it be this shitty Ca ethanol gas even thou its 91 octane?
Old Jul 25, 2015 | 03:47 PM
cutlassefi's Avatar
It rattles when you shut it off?
What are the build specs?
Old Jul 25, 2015 | 04:52 PM
Six8 x 43's Avatar
Build specs would be nice. What distributor is in it? Is it possible you're getting a bunch of mechanical advance in at idle?
By rattling at shut off do you mean dieseling? Be as specific as you can - there are a bunch of different variables that factor into the ignition system alone.
Old Jul 26, 2015 | 06:20 AM
rustyroger's Avatar
'87 Delta 88 Royale
What idle speed are you running?.
Roger.
Old Jul 26, 2015 | 08:12 AM
gs72's Avatar
72Cutlass S
Turn down your idle, 850 is too high. Either that of shut it down in drive if you are running an automatic.
Old Jul 26, 2015 | 09:49 AM
bw1339's Avatar
Higher initial timing will help with the dieseling, as well as give you better throttle response.
coppercutlass
Nov 9, 2013 10:12 AM
455Eldorado
May 19, 2011 09:57 PM
Bob Lynch
Tech Editor's Desk
May 11, 2010 10:05 AM
Bob Lynch
May 10, 2010 08:27 AM
82 Grocery Getter
May 10, 2009 09:57 AM
