76 455 in a 68 cutlass
I have a 68 cutlass supreme. It has a 350 but I am wanting to swap it for a 455. I have search and can not find the answer I am looking for but I found a 455 that came out of a 76 custom cruiser wagon. Will an engine from a 76 work? Or does it have to be before?
All Olds engines mount the same, so it will bolt in just fine. You will need to use the engine mounts for the 350 so that the 455 sits at the correct height. Mixing the engine mounts and frame pads for 350/455 results in the engine being at the wrong height.
To the OP, all 1965-1976 big block Olds motors (400, 425, and 455) are externally identical. Be sure to get the A-body exhaust manifolds (or headers if you choose) for your car.
The only difference that I can think of is that the drain petcocks is located differently on fullsize blocks, behind the motor mounts when in a-bodies, and that it probably doesn't have the treaded hole for the clutch linkage boss.
When in doubt, for your 455 powered car, pretend it's a 442 and order that part. E.g., if buying new motor mounts, and why wouldn't you, buy 'em for a '68 442. Buy exhaust manifolds or headers for a '68-72 442.
do not throw away ANY parts until you are done.
Compare the new part to the old - like motor mounts- and make sure the new will work.
Use the water pump and pulleys off the car's original engine unless you wish to use the '68 442 setup which is probably all different due to a different water pump. Water pump and pulley setups tend to be a matched set, so when you mix and match there it becomes a headache real fast.
brackets should all interchange- I believe the SB-only brackets came about for model year 1977, when the BB was dropped forever.
While the engine is out and you are putting all new freeze plugs in and whatnot, why not drill and tap the block drain bosses that will be uncovered with the motor mounts in place, so they can be used? 1/4" NPT pipe thread
Your 1976 455 will probably have HEI so that requires a new feed wire w/o resistor, and probably some bit of tailoring of the vacuum and mechanical advance and whatnot. The more changes you make, like headers and cam, etc., the more the spark curve will need attention.
'68 has some unique one year only things like the throttle cable. Are you changing '68 350 2bbl to '76 455 4-bbl?
And while Chris's info applies for headers (just don't ask for headers for a Supreme), if you choose stock manifolds you want the 69-72 W/Z manifolds, not the 68-only X/Y manifolds. The later ones have divided runners and flow better.
My car has a 4bbl. I found another engine for sale. Its a 70, and he wants 350 for it but it looks like its in rough shape. What do you think? I should be able to talk him down to 150 possible00d0d_dhLM1EYWvKH_600x450.jpg
00W0W_p2IopB1XXP_600x450.jpg.
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
