Another Spark Plug Dilemma.
Old Mar 27, 2015 | 04:12 PM
Hey, y'all. I've searched a lot of threads, but haven't found anybody with this exact problem. Besides, it'll give you an opportunity to laugh at my pain.
As we all know, the AC R44S plugs that sparked many of our beasts (including mine) are no more -- discontinued by the factory many years ago. I've been using R45S's and other Brand X cross-reference variants (Champion, NGK, Accel, etc.) and they've been mostly okay. But in the last couple of years, the engine has developed a light pinging at part throttle, so one of the ways I want to try to combat this is with a colder plug. But the only readily available alternative from AC is the R43S, which everybody on the interwebs seems to agree is WAY too cold to run on the street.
So, just for kicks and grins I called up my local Mom 'n' Pop parts store, and lo and behold, they had some R44S's way in the back of the shop gathering dust on a high shelf. The boxes were so old they actually said "Made in USA" on them! Twenty-five bucks -- how do you go wrong? I'll tell you how: they only had seven of them. I bought them anyway, figuring I could either find an orphan R44S somewhere, find a Brand X cross-reference to use for an eighth plug, or flip the damn things on Ebay if neither of first two plans worked out.
Well, it seems kind of like overkill to go to Ebay and go through the whole shipping thing to buy one spark plug, and besides all the lots I saw there were sets of eight. So, it was back to the parts store to find a cross-reference equivalent. Long story shortened (at least a little bit; stay with me here, we're nearly done) none of the other brands that cross reference to an AC R44S look ANYTHING like the R44S's that I have. Different reaches, different hexes, shrouded electrodes, weird extended tips, you name it, NONE of them was the same.
So, does anybody know what is the proper cross-reference for an AC R44S? At this point, I don't care what brand -- hell, if they look more or less the same I'll try one even if they're made in Tierra Del Fuego for J. C. Whitney.
Conversely, if anybody has a single R44S that they'd like to part with, I'm all ears.
Old Mar 27, 2015 | 04:22 PM
Your going to have to find another R44s, which as you found out is not easy. I think your going in the wrong direction, it's a timing issue. Check your total timing with vacuum advance and see where it is at around 3000 rpm. I bet it's too far advanced, over 52.
Old Mar 27, 2015 | 04:29 PM
Thanks, Eric. We've been down that road before, a whole other thread's worth, so I thought I'd try a different tack. Besides, I need new plugs anyway.
Old Mar 27, 2015 | 04:51 PM
tru-blue 442's Avatar
Old School Olds
I have had 3 orphans looking for another 5 for several years.
I thought they were made from unobtanium. 4 stripes, knurled bases.
Make me a nice offer and they are yours.
Edit: Mine are the 44S non-resistor. Oops, didn't mean to get your
hopes up like that, apologies.
Old Mar 27, 2015 | 05:12 PM
Well, the resistor thing may not be a deal-breaker. I'll keep them in mind. Thanks.
Old Mar 27, 2015 | 05:14 PM
Old School Olds
R44s
Well...I was looking through my others and found a beauty.
Old Mar 27, 2015 | 05:21 PM
You said in your other thread your using 91 octane, is there 93 available?
Old Mar 27, 2015 | 07:46 PM
You may be thinking about a different thread. We have ethanol-free Chevron 94 'round these parts and that's what I've used since I've had the car, so I consider myself lucky in that regard.
Old Mar 27, 2015 | 07:53 PM
Very interested. What would you need to make it worth the effort? Keep in mind (just to add to the PITA factor) that I'm in Canada.
Old Mar 27, 2015 | 08:10 PM
Old School Olds
PM sent.
Old Mar 28, 2015 | 05:20 AM
R-body_mopar's Avatar
Exclamation
Well, we have already been down this road , but your '69 400 engine, if it is nearly stock, was designed for Super Premium fuel (by virtue of it's compression ratio), such as Sunoco 260 LEADED, advertised at the time as 103.5 octane. To my knowledge, there is nothing available locally that even comes close to that!
As a longtime Olds driver, I went through this with two '70 442's with 455's, and a few others before them, (including two Mopars, a '69 383 HP and a '71 Duster 340), all high compression engines requiring PREMIUM fuel; I used to use Sunoco CAM II racing fuel mixed with premium unleaded, or Avgas lowlead similarly mixed. Also used Reallead tetraethyl lead additive as an octane booster; today's octane boosters available off the shelf are mostly alcohol concoctions only aggravating the problem, not solving it!
I also used Champion UJ10Y plugs, or J63Y and J61Y racing plugs, for a cooler heat range! The main problem back then was plug glazing of the porcelain from lead deposits from the fuel, not pinging from low octane fuel!
This link MAY help.....don't know!??
http://www.imps4ever.info/tech/engin...ark-plugs.html
Old Mar 28, 2015 | 09:44 AM
Ozzie's Avatar
This may no longer be needed, but here are some supposed cross overs:
Replacement spark plugs for AC DELCO R44S:
Old Mar 28, 2015 | 10:57 AM
Thanks very much -- it will definitely help, as the only model number nomenclature I really understand is AC. Probably why I keep buying them.
You're right about the 94 gas not being enough. I use an octane booster too.
Old Mar 28, 2015 | 11:03 AM
Thanks, Ozzie. That looks like the same list I've been using and the problem with it is that most of the plugs on there don't look anything like an AC R44S. The main criterion seems to be whether the sparkplug will screw into the hole!
Old Mar 28, 2015 | 11:04 AM
Anyway, looks like Tru-blu has one for me, so problem solved for now. Thanks, everyone!
Old Mar 31, 2015 | 09:54 AM
rocketraider's Avatar
Oldsdruid
Olds itself recommended 43's for high compression engines that saw mainly highway use and regular hard acceleration as that would keep the lead deposits burned off. The caveat in the shop book did say lead fouling would occur if these plugs were used putting around town at low speeds. I proved that with a 64 Starfire running a 30-70 mix of 100LL Avgas and 93 unleaded.
If you've been using 45's they are a little hot for today's so-called fuels. Are you on points or an electronic unit?
Old Mar 31, 2015 | 12:01 PM
HEI. I gap them at 0.045
bonesbmx
Jun 2, 2020 02:10 PM
snookys71olds
Apr 24, 2012 08:00 PM
ChrisM
Mar 7, 2009 08:07 PM
66starfire
Jan 3, 2007 10:31 AM
<james.reinhart@detroitdie>
Jul 24, 2004 09:34 PM
