455 HP/TQ question
Old Jan 15, 2015 | 06:59 PM
naphtali5725's Avatar
455 HP/TQ question
hello, wondered what you guys opinion would be for HP/TQ on my 455…
specs as best i can state...
Block bored .030 over
Honed with torque plates
Decked .010
Mains align honed
Crank turned/polished .010/.010, straightened
Factory rods reworked, ARP bolts
Factory cast high compression pistons advertised as 10.25:1 - .010 in the hole
Hastings moly rings
Clevite main/rod bearings
Melling high volume oil pump/pickup/drive rod
Rotating assembly balanced with dampener and flex plate installed
Clevite cam bearings
Bullet hyd flat tappet cam - .512 lift 230/284 duration on both int/ex on a 110 LS
Matching valve springs 110lbs closed, 285lbs open
Cloyes true double roller timing set
J-heads reworked (bowl hog, not ported) milled .022, new 2.07 int and 1.68 exhaust valves
New lifters/pushrods/rocker arms
Stock 4 barrel intake
Modified 800cfm Quadrajet, 76 main jets - 48 primary rods - DB secondary rods
All Felpro gaskets
Old Jan 16, 2015 | 03:48 AM
grampy's Avatar
About 400 horespower @ 4800 .if you are using headers.my combo is really close to yours same camshaft q jet ,performer ,compression headder and ga heads.I run 75-49 DA in my quadrajet so your jetting will be close.
Old Jan 16, 2015 | 04:08 AM
thanks grampy… how much torque do you think? is that cam pretty good on the street?
Old Jan 16, 2015 | 04:24 AM
grampy's Avatar
Plenty of TQ .I run a 3.73 gear radial tires are useless it will roast the tires on a 30 mph roll in 3 gear.you could get away with a 3.23 rear gear with a tight 10 inch converter.my idle vacume is 14 @700 out of gear.
you might need to richen up your secondary rods in your quadrajet your rods are little lean,stock 403 quadrajets came with CV rods.
Old Jan 16, 2015 | 04:28 AM
you might need to richen up your secondary rods in your quadrajet your rods are little lean.
ok, cool... i have a 9" posi 3.25 rear gear, TH400 with 2400 stall
i'll check into the richer secondary rods when I get the motor in my truck...
thanks grampy!
yeahbuddy
Dec 19, 2011 08:40 PM
buddiiee
Jan 9, 2008 10:50 PM
tsimpsonaz
Dec 10, 2007 03:32 PM
bennymac
Apr 27, 2007 04:51 AM
taguy1979
Jun 21, 2004 11:01 PM
