ready to build
Old May 14, 2014 | 10:11 PM
mike74442's Avatar
ready to build
I bought a 68 455 F block a few weeks ago I'm looking for a street build not sure which way to go with it. I need heads and I have a 650 double holly carb should I upgrade the carb? I'm not very educated on these older cars yet.
Old May 15, 2014 | 03:35 AM
billmerbach's Avatar
major noob
Well 650 seems decent to me but what are you numbers you want to obtain
Old May 15, 2014 | 04:49 AM
cutlassefi's Avatar
650 is small, even for a mild 455. 750 should be the minimum.
Old May 15, 2014 | 04:53 AM
70cutty's Avatar
Beer Connoisseur
650 is too small. As far as the heads go look into Procomp's aluminum heads, best bang for the buck.
Old May 15, 2014 | 05:21 AM
Smitty275's Avatar
Engine Builder
You need to give us an idea of what you want out of the engine and how youAre going to use it. Basic cruiser, hot street, street/strip, or strip only. With that info a plan can be hatched.
Old May 15, 2014 | 08:47 AM
mike74442's Avatar
IIll definitely be a street car I just want it to be able to pick up and go so I'm not embarrassed when someone trys to race me even though most of the cars are tuners or old school cars with big rims around here haha. My budget isn't super high I have about 3000 to start and a couple hundred to spend a month on top of that. It is an olds so the more torque the better as long as I don't risk messing anything up. I just need a starter build for dummies for right now.
Old May 15, 2014 | 10:35 AM
Smitty275's Avatar
Engine Builder
Food for thought. If you build the short block properly, which will cost a little more than a basic rebuild, you can continue to improve the heads, intake, cam, etc., as the years go by. Doing so saves you a lot of money in the long run. I've seen guys throw a lot of money away because they built engine after engine each time with a minor internal upgrade to go with a new set if heads or whatever. So think it over. The machine work is going to cost the same no matter what parts you put inside it. If you can hold out to buy a few hundred bucks worth of better parts you'll save thousands upon thousands in the long run.
Old May 23, 2014 | 08:04 AM
mike74442's Avatar
Just an update I bought some c heads for dirt cheap no cracks or anything it's coming along cheap and fast thanks for the advice.
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
Cardoc
Nov 20, 2007 09:04 AM
69 442 protour
Dec 9, 2006 09:25 PM
84cutty
Sep 8, 2006 12:32 AM
