455" Assembly Tip
Old December 6th, 2013, 12:31 PM
GOSFAST's Avatar
455" Assembly Tip
We are in the process of assembling a 455" with some Eagle conn rods, stock crank, stock stroke and had an issue AFTER the pan and pump was installed.
You have to look closely at the distance between the cotter pin in the oil pump housing and the number 8 connecting rod as it goes through it's cycle! The one rod bolt ended up contacting the head of the pin.
Just touching enough to make a very slight "ticking" sound while turning the short block over.
Thanks, Gary in N.Y.
P.S. Had we been doing a stroker it probably would have been somewhat closer still.
GOSFAST is offline
Old December 6th, 2013, 12:43 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Good to know. Thanks Gary.
J-(Chicago) is offline
Old December 9th, 2013, 09:32 AM
Octania's Avatar
closer than hitting?
I was putting together a 455 a while back when I found out why some pumps have a cutaway on the relief valve snout. 'Cause the crank/rod had about 0.100" interference there!
Octania is offline
tomngary
September 18th, 2013 05:22 PM
Dave Siltman
September 28th, 2012 12:02 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
Ryhelio
July 7th, 2007 11:49 AM
Quick Reply: 455" Assembly Tip
