Single lifter replacement?
Hello all
I need some help/guidance, has anyone ever replaced just a single lifter with an old cam,true mileage of engine /cam is unknown.
not sure what could have caused the lifter surface problem, cam does not look to have been affected , not sure how long this lifter has been this way.
Thanks in advance
Pat
Thanks in advance
Pat
Have replaced lifters without replacing the cam and it has worked without any problems. Look at the cam lobes and other lifters very closely for similar wear and if you do find some then I would replace them all. Read that the others were fine, were you able to examine them really well? If the others do look excellent then you can replace just one.
An easy way to examine lifters is to place another lifter perpendicular as a straight edge across the bottom tappet surface to check for straightness. IMHO if the tappet surface is flat, not discolored, the lifters did not tap and has zero pitting then re-use is fine.
Hello all
Thanks in advance
Pat
Thanks in advance
Pat
If the lobe is damaged, the cam is gone.
Stanley
Thank you all for the valuable input and observations , as for the the cam that Oldwolf mentioned looked damaged(shrp eye) what he saw is the shadow/reflection from the empty valve lfter bore, as I removed the lifter to take a picture, all the lobes look good on the cam, no other lifters had any issues.
I will roll the dice for a $7.90 lifter and reassemble. MD weather is not nice right now, so engine will be shrink wrapped for now, I will update the thread after fire up , Happy Holidays to all
Back in the day, I'd do that and it always worked. Seems like everything worked back then. (1960's/70's) Money was tight. Dial indicator can tell you how much lobe wear. Coat the new lifter with assembly lube. Jmo, Ken
good tip..assembly lube from permatex, sealed power lifter HT-951 7.90, local hard parts house had part in one day, planning on coating all pushrod ends and lifter cups with assembly lube as well as base remaining lifters, I did remove and reinsatll all lifters in same position when completing inspection, I was able to get the cam part # from the shaft 40134 (lunati???)
point taken, I looked at the lifter and noted a ever so slight crown under the area where metal is missing.
I have removed the oil pan, oil pick up cleaned no metal shavings noted , I removed 1 crank bearing cap and rod bearing for inspection and did not note any major issues.
thx
thx
thx
thx
