425 Tappet Bank Angle
Old Oct 1, 2013 | 12:12 PM
Old Olds Fan's Avatar
Question 425 Tappet Bank Angle
I would like to build a 425. I know that there are 2 different tappet bank angles and different diameter tappets. The 39 degree .921 dia. block was the hot ticket of the day, but the major components in both engines were the same. What is the down side of using a 45 degree .842 dia. block as the basis of a performance build? 2cd. Question; Max bore on 400 V/S 425?
Old Oct 1, 2013 | 01:44 PM
Kennybill's Avatar
Just because it has .842 lifters doesn't mean it is a 45º block. All 1967 425 engines I have/have seen were 39º engines. The 1965 & 1966 425 small lifters were 45º. The cam 45º cores are getting harder to find but you can get them. Comp Cam was out but check anyway. The 425's are excellent engines to build either cam bank angle. Jmo, Ken
Old Oct 2, 2013 | 05:07 AM
BILL DEMMER's Avatar
Just the facts...
if you want to be sure about what you have, check the lifter bank angle for yourself. my '67 425 is a 45* lba with .842 lifters.
bill
Old Oct 2, 2013 | 05:19 AM
cutlassefi's Avatar
bill
X2.
If you want to go roller then the 39deg/.921 lifter block would be the most practical.
You can get roller cores for the 45 degree stuff but they're twice the cost of the 39's.
All you need to use a roller in a .921 block is the spider and dog bones from a diesel or roller 307. Then you're good to go.
I'd go with the 425 block with the bigger bore but it's always a good idea to have them checked anyway.
lemoldsnut
Tech Editor's Desk
Jun 29, 2015 10:26 PM
jhoppeolds
Aug 21, 2014 05:26 PM
Octania
Jun 1, 2014 12:21 PM
raymondh36965
Mar 24, 2010 06:10 AM
nonhog
Aug 25, 2009 03:59 PM
