diagnostics advice olds 425 toro
Old May 20, 2013 | 02:03 PM
lowkey235's Avatar
I am concerned about blow by I get a lot of white smoke from my valve cover breather, hardly any from exhaust, I havent done a compression test yet. my fear is piston rings, do these symptoms seem right? I will do the compression test when I get the tools this week, dry and wet. off hand anyone know what cylider pressures i should be looking for, its a high mileage engine and I know it needs freshend but was hoping not to jump in all at once.
Old May 20, 2013 | 03:13 PM
Erinyes's Avatar
Main thing to look for (as I'm sure you know) is consistency between cylinders, within say 5%. That being said, as long as you're getting maybe 120 psi or more I'd be satisfied. For diagnostics, it will help quite a bit to know the details of the engine and the results of the wet/dry tests.
Old May 20, 2013 | 03:25 PM
Also make sure your pcv is functioning properly.
Old May 23, 2013 | 09:01 AM
Old Olds Fan's Avatar
either take off the breather cap and look for moisture or better yet the value cover (actual water droplets and white emulsified oil) if so you've blown a head gskt., or broken the block or heads, possibly a water leak from the intake crossover but it would have to be getting through the valley pan, you're looking for how water got in you crank case. Frequently you can drain the oil and not see anything (very small leak) Though there will be mud in the pan, stuck to the bottom.
Old May 23, 2013 | 06:21 PM
BILL DEMMER's Avatar
Just the facts...
iirc, the factory says a max. of 10% variation is allowable.
bill
Old May 23, 2013 | 08:05 PM
lowkey235's Avatar
Thanks for the information, I hope to do the compression test this weekend, about the wet test...just a couple of ounces of motor oil in the sparkplug hole how long does it take to get rid of oil in the cylinders?
Old May 24, 2013 | 08:08 AM
Erinyes's Avatar
I could be wrong, but I always thought just two or three squirts of oil. A couple ounces per cylinder seems excessive.
Old May 24, 2013 | 08:47 AM
Just the facts...
wasn't the amount of oil to use like a teaspoon? you only want enough to coat the ring to wall surface-you don't want to hydro-lock your motor.
bill
Old May 24, 2013 | 08:59 AM
A couple of ounces will bend a rod.
Old May 24, 2013 | 01:43 PM
lowkey235's Avatar
compression test is done, i used a capfull of oil for the wet test. this was done with a harbor freight gauge so take with a grain of salt I guess. cylinder#, dry/wet
1,30/40 2,90/150 3,120/120 4,70/135 5,88/120 6,120/145 7,30/40 8,120/150 I wasnt sure how long to crank the engine so I dont know if these are accurate IMAG0301.jpg
Old May 24, 2013 | 01:52 PM
You have issues with #1 and 7. I crank the engine until the gauge won't go any higher.
From your pic, you have some issues beyond a normal old age engine.
Old May 24, 2013 | 01:54 PM
lowkey235's Avatar
oops i did it on a cold engine, I might retest saturday after I warm it up, looks like I have a rebuild coming in the near future, now the debate is rebuild the 425 or look for a 455 core. ballpark how much to re ring the pistons? I can pull the heads and such but have no facilities to pull the engine.
Old May 24, 2013 | 04:16 PM
Just the facts...
jmo, you need a complete rebuild. it looks like your valves are pretty weak. i'd rebuild the 425 and skip a 455.
bill
Old May 24, 2013 | 04:31 PM
x2 on rebuilding the 425.
Old May 28, 2013 | 11:28 AM
lowkey235's Avatar
rebuild
I am new to this, is $3000 a good ballpark to rebuild the engine. parts and labor, I know there is no telling how much machine work until its apart, but I think a rebuild is above my skill level so I will have to get it done at a shop.
Old May 28, 2013 | 11:38 AM
$3-5000 with a shop. It all depends on how much machine work and are needed.
Old May 28, 2013 | 07:47 PM
442rocketdave's Avatar
You may pull it apart and find your ringlands broken, it happens to the pistons after years of use and with the blow by and problems in #1 and #7 that could be the culprit.
grubin
Dec 1, 2014 06:59 PM
tbristol
Apr 11, 2014 01:27 PM
costpenn
Feb 1, 2012 03:41 PM
Threejdsolds
Apr 29, 2009 07:49 AM
ijasond
May 13, 2008 08:27 AM
