Ebrok heads and split cam duration and lift?
Old December 14th, 2012, 07:26 PM
Bernhard's Avatar
Whith the ebrock heads does the 455 still like cams with split duration and lift? Are cams with larger exhaust duration and lift a thing of the past?
Bernhard is offline
Old December 14th, 2012, 08:37 PM
70Wcars's Avatar
Cams with split lift and duration still work very well...even with the Ebrocks.
What are your plans/goals for the engine/car?
Danny
70Wcars is offline
Old December 14th, 2012, 09:44 PM
Hot Rod Has Been
krooser's Avatar
I just had a custom cam ground for my 330 circle track build and we actually went with a shorter duration and lift on the exhaust to deal with exhaust reversion problems that come with using cast iron exhaust running laps at over 6500 rpm's...
Who knew?
krooser is offline
Old December 14th, 2012, 10:01 PM
Bernhard's Avatar
Fun street car that's only driven in the summer.Car will see the track form time to time. Car is a 86 G body cutlass with all the factory rare parts.Alum hood, bumper supports,rad support,drums.Radio delete/front plate delete/lightning rod shifters,H/O gauges. 8.5 diff,2004r from a ss. I would like to build a max value 455,best dollar value for money spent.mid 12's to low 11's.
Ebrock heads out of the box
egale rods
cn crank
studs with stock caps
light piston and pin
10 to 1 to 10.5 to 1 comp
pump gas 93 to 94
holly street dom intake I hope this intake fits under the factory alum hood.
headers
roller rockers
hyd flat tapet cam? duration? Lift? I was thinking about going with a Dave Smith cam grind
Block will be blue printed
800 cfm qjet
3:73 gears
Bernhard is offline
Old December 15th, 2012, 06:23 AM
cutlassefi's Avatar
I'd do a split but I'd keep it to a minimum with your combo, depending on how high you'll be spinning it maybe a 236/240 on a 110, with .568 lift to use those heads. I offer that cam in the Erson line.
cutlassefi is offline
Old December 15th, 2012, 10:54 AM
Bernhard's Avatar
The goal is to have a car that is quick but does not break parts.Street friendly.I want the car to work, there is know point to 500hp 600TQ engine if it breaks parts.I also have a limited budget.The diff is a 8.5 that will get axles,a pre load cover and ford ends.A built 2004r. with some billet hard parts.
I would like to match the engine to the diff and trans power level with a margin of safety.
I want to keep engine rpm down to 5200 to 5600 max rpm.
It would be great if the car could run a mid 11's in good air with a strip set up. I will give up et for a more street friendly car that does not break.
My goal is to have the car weigh 3000lb with out driver. No cutting up of the body and must look 100% stock except for the wheels and tires.
I was even thinking of painting the heads and intake gold.The goal is to have it look like GM built the car, its hard to hide the heads,intake and headers.I'm hoping to fab up a drop base factory air cleaner.
Bernhard is offline
Old December 15th, 2012, 11:30 AM
Milan..'s Avatar
I like to use a fair amount of duration spilt , E-brocks ported or stock are weak in exhaust flow at least 6-8 deg of more split helps that. I also like 112 lsa , long rod and long stroke motors have lots of piston dwell , and dont need a ton of overlap.A 112 lsa will also help the motor hang on longer at max rpm , but will flatten the torque curve (lower peak torque) a bit. I would guess 230-34 intake and 238-42. Hey Mark , will you be re-dynoing soon?
Milan.. is offline
Old December 15th, 2012, 03:29 PM
Bernhard's Avatar
I was reading the ebrock head speck sheet and in stock form they looked to peak around .500 lift and did not flow that much more over .500. Is there still good gains to run a higher lift cam? How are the Erson cam profiles are they easy or hard on the valve train? Are they still made in the USA?
Bernhard is offline
Old December 15th, 2012, 03:40 PM
ah64pilot's Avatar
You don't need excessive lift, but you will see more power with over .500" lift with the Edelbrocks.
I have a split duration cam, .557 / .574 lift, 244 / 253 duration @ .050" in my silver car and I love it. It is a street car, but it does idle really rough for a cruiser. It all depends on your goal, I want a streetable drag car whereas most guys want a dragable street car.
ah64pilot is offline
Old December 15th, 2012, 05:39 PM
captjim's Avatar
Want the best of both worlds? Nitrous. It is going to be tough to run mid 11s spinning it up to 5200. You can with nitrous and it will require lerss gear. Build a stout small block, run high 13s with a 3.42 gear, get decent mileage and reliability, mild cam with great manners. Push a button and run a high 11. My VERY mild 355 ran 12.7 in a 3800 lb car with a 100 shot shifting at 4800. SBO is easier, stronger, no need for E-brocks or fancy stuff. Just a thought....
captjim is offline
Old December 15th, 2012, 06:27 PM
442rocketdave's Avatar
Captjim is right on that one and if your going to keep the 455, why not use the edelbrock performer and you will have clearance under the hood. The cam AH64pilot has is almost the same that I have and it runs great! But a 350 olds built right will kick but with the nitrous!! and be completely streetable. Something to think about
442rocketdave is offline
Old December 15th, 2012, 07:20 PM
Bernhard's Avatar
Thanks for all the replys. Lots of good info,I'm going to stick with the 455. I have a new holly street dom left over form the 80's as well as few ohter big block parts.If the street dom does not fit I will mill the carb base or go to the performer.
Thanks again
Bernhard
Bernhard is offline
Old December 16th, 2012, 06:00 AM
cutlassefi's Avatar
The newer Erson profiles were designed by Hans Herman of Germany. Yes they are aggressive but are very compatible with even stock valvetrain parts when in the lower lift ranges.
Yes everything is still made in the USA, cam cores, lifters, timing sets etc.
Old December 18th, 2012, 12:44 PM
jfb
jfb's Avatar
I prefer like pilot a all out street car that can be driven also. I believe in the term let it all hang out and then be buried with your baby also! I also believe in not harming anything a [powerful car is not a toy! do not go overboard with the gears unless you are using a overdrive. I use engle cams only.
jfb is offline
leepear
October 23rd, 2013 03:03 PM
e129745
May 12th, 2012 03:40 AM
72fastback
June 15th, 2011 10:21 PM
TripDeuces
June 17th, 2010 02:29 PM
jensenracing77
May 1st, 2009 02:35 PM
Quick Reply: Ebrok heads and split cam duration and lift?
