oil filler breather cap
Old Jul 30, 2012 | 12:11 PM
1971viking's Avatar
I am having problems with my valve cover breathers making a mess of my engine. Oil is seeping out the top. Just enough to get things messy. My valve covers are the old Mickey Thompson with the square breathers.
I was told to use a oil filler cap with a breather line that goes to the vacuum on the carb.
Has anyoone had this problem and fixed it by using this method?
Old Jul 30, 2012 | 12:19 PM
How's your PCV, what you have is probably some blowby.
Old Jul 30, 2012 | 12:30 PM
1971viking's Avatar
No PCV. I don't want to drill a hole in my holley street dominator manifold.
Old Jul 30, 2012 | 12:54 PM
Well then you are not going to solve tis problem. If you seal the breathers so as they do not leak. The pressure in the engine will just find somewhere else to blow out. What about drilling one of your valve covers for a PCV and gommet?
Old Jul 30, 2012 | 01:02 PM
1971viking's Avatar
That was also an option but I wanted to try using a oil filler cap with a breather line that goes to a PCV and then to the vacuum on the carb.
Will that work?
Old Jul 30, 2012 | 01:08 PM
Will that work?
Are you talking about through the oil fill tube, or the valve cover?
Old Jul 30, 2012 | 01:28 PM
1971viking's Avatar
Using the filler cap as a breather.
Old Jul 30, 2012 | 01:36 PM
That with an inline PCV will probably work. Something like this:
http://www.summitracing.com/parts/SMP-V112/
You can probably get this at your local parts house.
Old Jul 30, 2012 | 01:55 PM
1971viking's Avatar
Yes. Thanks
63super88
Jan 23, 2014 08:17 AM
EightyEightCut
Aug 25, 2012 11:19 PM
Cameo White
Hurst/Olds
15
Apr 29, 2010 01:16 PM
68Tom
May 24, 2009 12:53 AM
edj1993
Jul 9, 2008 09:53 AM
