In what order do the wires go on dist cap?
Old Mar 31, 2011 | 10:41 AM
70 delta 88's Avatar
Plugs and wires were already off when I bought the car just trying to put new plugs and wires on it, 455 rocket. Just wanted to know in what order do the wires go on the cap.
Old Mar 31, 2011 | 10:46 AM
Same as the order cast into the intake manifold.
I don't remember it, because I always look at the intake manifold (but I know Joe does...).
It turns counterclockwise.
Old Mar 31, 2011 | 11:00 AM
Oldsmaniac's Avatar
18436572 counter clockwise #1 can be anywhere but usually just to left of adjusting window on cap
Old Mar 31, 2011 | 11:25 AM
Bluevista's Avatar
Registered
Every red blooded American boy should know those numbers by heart.
I have since since before I could walk.
The password in war should be "Tell me the GM V8 firing order or I'll shoot!".
I have two girls but if my wife ever had a boy his name was going to be 18436572 Wolf.
Old Mar 31, 2011 | 12:14 PM
Lady72nRob71's Avatar
CCW.
Righty-wrongie, lefty-righty!
Old Mar 31, 2011 | 12:31 PM
Thanks Guys!!
Old Mar 31, 2011 | 12:51 PM
I have the wires straighted out, even double checked them. It act like it wants to start but back fires, What do I do next?
Old Mar 31, 2011 | 01:29 PM
Oldsmaniac's Avatar
Maybe distributer was not put in right, bring #1 piston up on TDC compression stroke and make sure rotor is pointing to "1 plug wire on dist cap
Old Mar 31, 2011 | 01:30 PM
Get cylinder #1 to tdc and set your #1 on the cap where the rotor is pointing to. If you had your dist. out your possibly 180 deg's out!
Old Mar 31, 2011 | 01:45 PM
I'm glad to see that you guys finally have the firing order memorized.
Backfiring usually indicates that the timing is way off. As noted, get the #1 cylinder (driver's side front) to TDC on the compression stroke, look at where the rotor is pointed relative to the distributor cap, start with the #1 plug wire on that tower, and go CCW from there. The exact location of #1 on the cap doesn't matter, just that the rotor points to it when that cylinder is on compression.
Old Apr 1, 2011 | 12:13 PM
Thanks for the helps guys, it worked!!
Old Apr 1, 2011 | 12:26 PM
gearheads78's Avatar
car guy
When I first put my 66 back together I spent hours pulling my hair out trying to get it to run with 18436572 clockwise It was my first Olds motor to work on.
Old Apr 1, 2011 | 01:07 PM
citcapp's Avatar
The exception being if you have a 4-7 swap cam as some people have found out Not saying who
Old Apr 1, 2011 | 01:19 PM
panos's Avatar
Ha ha
Old Apr 1, 2011 | 01:47 PM
66luvr's Avatar
Yeah I knew the v8 order pretty early, but before that I knew the 153624 for the 6cyl Chevys.
Mike
Old Apr 1, 2011 | 03:09 PM
oldsconv's Avatar
Yes - I did the same thing - I was out about 1/8 of a turn on the distributer which put the timing way off and caused the backfire.
If you want to get ****, the chassis service manual has a diagram of exactly where the wires go into the cap.
Hawghead
Jul 18, 2014 12:51 PM
Octania
Jul 9, 2014 12:56 PM
joepenoso
May 28, 2014 11:09 AM
Blue71Cutlass
Sep 18, 2011 10:59 AM
72rocket
Dec 30, 2008 08:31 AM
