intake gasket
Old Oct 25, 2010 | 07:22 PM
808olds's Avatar
intake gasket
anyone know where i can get a intake gasket that blocks off the exhaust crossover on the intake manifold?
Old Oct 25, 2010 | 07:40 PM
jensenracing77's Avatar
if the port is not blocked off, it will just burn through the gasket. i know that Mondello has them but i would think you can get them other places. i think i have a set for a big block that i won't use if you can't find them.
Old Oct 25, 2010 | 09:38 PM
808olds's Avatar
so i need a shop to weld it closed ? then gasket?
Old Oct 26, 2010 | 04:57 AM
i am far from an expert on this subject but i had a set of the gaskets like that on my Rallye 350. about 250 miles later i changed the intake and they were burned through.
Old Oct 26, 2010 | 08:24 AM
Rickman48's Avatar
'Back in the day', we used to cut sheet metal bigger than the hole, and let the gasket hold it in.
Don't remember any 'burn-throughs'!
Old Oct 26, 2010 | 03:59 PM
Destructor's Avatar
If you can find out the crush thickness then use a piece of sheet metal no thicker than that you could then cut a hole in the gasket slightly bigger than the crossover hole for the sheet metal. Use the old turkey tray as a template.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
