Need a new carb any recomendations??
Old Sep 20, 2010 | 10:14 AM
65Delta88's Avatar
I have a '65 425 in my '65 Delta 88 its a high compression motor, I have an Edlebrok performer intake manifold, dual exhausts with an "S" manifold, and I currently have a Holley 750cfm 4160 series carb on there (vac secondaries) and it began to leak and flood out. I am wondering if there would be a better carb that I could choose for my setup? Smaller CFM? different series or brand? If it makes any difference I plan on putting a larger cam in and some roller tipped rockers this winter. The car has 3.08 gears in it, stock trans and only winds out to about 4000 rpm.
Suggestion will be much appreciated!!
Old Sep 20, 2010 | 12:02 PM
Have you considered rebuilding your Holley?
Old Sep 20, 2010 | 01:17 PM
philnjean's Avatar
I agree. You might want to consider rebuilding your holley. Don't think you have to much carb for it.
Old Sep 20, 2010 | 01:48 PM
citcapp's Avatar
Sounds to me like the float is sticking. Try running some carb cleaner through it before you get to carried away with buying things
Old Sep 20, 2010 | 02:00 PM
I think we should suggest looking at the OTHER carb selection thread...
Old Sep 20, 2010 | 02:42 PM
Warhead's Avatar
buhWAHAHAHA
Now THAT is funny!
I say do what you can afford to do. Even if it means an AFB.
Your car.
Good luck.
Jim
63super88
Feb 19, 2014 03:04 PM
63super88
Feb 5, 2014 10:40 AM
66ninetyeightls
Sep 23, 2009 07:27 PM
PmL69
Paint
Jul 6, 2009 05:04 PM
craftsmen22
Jan 18, 2009 02:41 PM
