Felpro 1356 intake gasket
These don't require RTV on the water ports, but I would put a couple of small dabs on them to keep them from moving on the heads while you set the intake down. But for sure ditch the end seals and just lay down a bead of RTV instead.
You rather forgot to mention what type of rtv you are planning to use. ABSOLUTELY NO blue rtv. That crap should be banned from production. On the end use ultra grey or ultra blue. Grey is better but you MUST make sure the surfaces are CLEAN. Then lay down a bead,torque it down and then lay an external bead to seal the corners,front and back. Do this across the entire bead. No way you have a leak after this.
