valve cover oil leaking
Old Jan 20, 2010 | 01:52 PM
442 Guatemala's Avatar
Angry valve cover oil leaking
Hello, I just build my 400 engine (1966 442) put like 500 kms on it.
But the Oil leaking from the breather of the valve cover (co-pilot side) is drive me crazy, its too much.... every time I put a little gas on the car, the oil starts leaking from the breather...
I have some questions:
1. what can cause all this oil leaking?? I measure the compressions of each cylinder and im between 160-180, so I dont think im having a blow-by???
2. is that normal on olds engines?
3. Do I build something wrong in my engine?
4. Is necessary for the engine to breathe from both sides or can I put like a tampon on the leaking side?
thanks for the help
Old Jan 20, 2010 | 09:34 PM
64Rocket's Avatar
Do you have the "PCV" valve hooked up? It seams to me the PCV valve should be on the passenger side and the breather on the drivers side.
Gene
Old Jan 21, 2010 | 09:13 AM
I dont have a PCV valve intalled, what im worried about is if I install the pcv valve on passenger side, the valve is going to suck all the oil?? and then damage my carburetor, etc???
Gene
StarGeneral
May 5, 2014 06:28 AM
jpc647
Sep 10, 2012 06:54 PM
defiant1
Aug 26, 2011 09:45 AM
yeahbuddy
Aug 17, 2010 12:47 AM
