valve lash
Old Jun 11, 2026 | 02:55 PM
Ecpirate's Avatar
valve lash
Greetings all. My 1967 Olds Delta 88 has a 425 engine. It has hydraulic lifters. My rocker arms have been coming loose after after 30 - 40 minutes of running. They will come off of the push rods. If I tighten down on the bolts, holding the rocker arms to the head I cannot turn the push rod. However, this does stop the rockers coming loose. Will it hurt the valves if I tighten the bolts tight enough so that they don't come loose. Any help is greatly appreciated. Thanks.
Old Jun 11, 2026 | 03:07 PM
v8al's Avatar
Registered Olds Owner
We need to know if you have a stock or an aftermarket rocker arm setup.
Let us know what you have. If you don't know, take a picture of your cylinder heads that shows the rocker arms so people know what type you are dealing with.
If this is a stock non adjustable factory rocker arm setup the rocker arm bolts should be torqued to 25 foot pounds.
Old Jun 11, 2026 | 03:13 PM
Ecpirate's Avatar
Thanks so much for your reply. This is an original stock engine. I had previously torqued the bolts to 25 ft/lbs but I could not twist the push rods. However, the rockers did not come loose. I go back to the 25lb torque. Thanks again.
Old Jun 11, 2026 | 03:18 PM
v8al's Avatar
Tighten each rocker bridge slowly, working back and forth between each bolt on a single bridge. Make sure bridge goes down "squarely" so you don't put any type of side load on the bridge. Once a bridge is fully snug on the head (both sides), torque to the final 25 ft lbs. Then move onto the next rocker bridge.
Old Jun 11, 2026 | 03:26 PM
Ecpirate's Avatar
will do. Thanks again and take care.
Old Jun 13, 2026 | 05:19 PM
BillK's Avatar
Are the rocker arm bolts actually loosening or is something else happening that is allowing the pushrods to get loose ? When you check them can you actually turn the bolts and tighten them more ?
Do you have an oil pressure gauge in the car ?
Old Jun 16, 2026 | 06:25 AM
Ecpirate's Avatar
Hi Bill, and thanks for your reply. The bolts were coming loose and the rocker arms would fall off the valves. I tightened to 25 lb. torque and all is good.
user 7408240824
Apr 22, 2020 06:46 PM
RROLDSX
Dec 12, 2016 09:01 PM
Arrowstorm
Jan 27, 2015 03:38 PM
knighthawk
May 18, 2011 05:30 PM
gibbo69olds
Apr 24, 2008 12:29 PM
