Another 455 build issue - noisy oil pump
Old Mar 15, 2026 | 09:41 AM
PaulWinn's Avatar
Got my 455 ready to drop in - filled with oil and filter and did the priming. Got good pressure but also quite noisy. A steady grrrrrr. Something tells me my pickup might be touching the pan? Anybody ever have this noise? Now is the time to fix it if indeed it is touching. All stock parts here
Old Mar 15, 2026 | 10:13 AM
BillK's Avatar
This is why I always pre-oil them on the engine stand. Did you build the engine ? Also Its very subjective as to what is "noisy" Here is a link to a couple of videos I did when I built a 425 a couple of years ago: Maybe compare your sound to this one. This was a stock Melling pump.
Old Mar 15, 2026 | 11:31 AM
PaulWinn's Avatar
I did the build - first Olds but done maybe 30 Chevys and Fords. I am used to the light oil pump sound of a wet clickity click but not a GRRRR. I did a 10 sec.video but it won't post here? And yes the drill sound kinda drowns it out on a video. The sound is also very very different at different speeds - about 120 rpm it is LOUD and low pitch
Old Mar 15, 2026 | 12:30 PM
cutlassefi's Avatar
Melling/Olds pumps suck. I’ve been back and forth with them for years regarding their poorly machined gears in these.
I take em apart, have the gears coated, check clearances, and put em back together.
Old Mar 15, 2026 | 06:29 PM
PaulWinn's Avatar
I can feel the vibrations on the bottom of the pan. Is there a chance my drain bolt is touching the pickup? Or are they not close to the same location?
Old Mar 15, 2026 | 06:57 PM
BillK's Avatar
Paul,
Drain the oil out and try it without the drain plug ? Or look in through the drain hole and see if the screen is right there ? I dont think you can post a video here directly. You need to put it on You Tube and then post a link like I did.
Old Mar 16, 2026 | 05:43 AM
cutlassefi's Avatar
Did you measure the clearance between the pick up and the pan but when you assembled it?
Old Mar 16, 2026 | 06:23 AM
PaulWinn's Avatar
I did not - it was a.bolt on pickup so I took for granted it was the correct height. Looks like I'll find out tonight
Old Mar 16, 2026 | 07:21 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As Mark said, they are noisy. I believe Mark even had a couple fail. He sold me his best spare pump when was really having issues with them. It is notchy feeling and a bit noisy but has borderline too high cold oil pressure with high volume pump and purple spring using 10W30 VR1.
Old Mar 16, 2026 | 09:43 AM
PaulWinn's Avatar
Yes, "notchy" is a good description of the feel and sound
Old Mar 16, 2026 | 11:32 AM
BillK's Avatar
Stock pump or HV ?
Old Mar 16, 2026 | 12:30 PM
PaulWinn's Avatar
Hv
Old Mar 16, 2026 | 12:46 PM
BillK's Avatar
Hv
Interesting. I have a standard M22F and a M22FHV pump here and I just put a little oil in both of them and turning them by hand they are about as smooth as any pump I have felt.
Old Mar 16, 2026 | 12:49 PM
cutlassefi's Avatar
Hmmm, so you don’t check that even on all the Chevies and Fords you’ve done?
That’s an amateur mistake, sorry.
Old Mar 16, 2026 | 01:22 PM
PaulWinn's Avatar
Well in my defense on Chevrolets you have to press in the pickup and adjust for height. This one is a bolt on (hv) and is not adjustable, so I assumed some engineer had it all figured out
Old Mar 16, 2026 | 03:31 PM
v8al's Avatar
Registered Olds Owner
I recall once I had the lock washers on the oil pump drive rubbing on the main cap. I don't really remember the specifics though.
Maybe the washers are not positioned correctly?
Another possibility is maybe your side loading the shaft while priming and it's rubbing against the block.
Old Mar 16, 2026 | 04:03 PM
cutlassefi's Avatar
Never assume. Not a good way to go about this.
Chances are you just have a notchy pump.
Old Mar 16, 2026 | 06:22 PM
PaulWinn's Avatar
Drained the pan and confirmed the drain plug bolt is not touching the pickup. I'll pop the pan off tomorrow. Thanks for the tips
Old Mar 21, 2026 | 06:47 PM
PaulWinn's Avatar
Might be 2 problems - yes I have a noisy pump, like REALLY loud. Took it apart and I don't see anything wrong, no scars or chunks. Id say poor finish machining. AND the pickup is touching the pan. Tomorrow I'll run grab another pump and give it a try.
Old Mar 21, 2026 | 10:07 PM
v8al's Avatar
FYI - another option - Precision Oil Pumps.
Old Mar 22, 2026 | 07:20 AM
cutlassefi's Avatar
I don’t recommend those anymore. They round out the gears which results in less pressure and flow.
i take the gears and have then coated, big improvement.
Old Mar 22, 2026 | 07:23 AM
cutlassefi's Avatar
Trying another pump is no guarantee it’ll be any better, trust me.
Had you checked all this before you would’ve saved yourself this trouble right? Hopefully this was a learning experience for you.
Take the pump apart and have the gears coated by Swain, Calico or similar. That should fix that issue.
Old Mar 22, 2026 | 12:05 PM
CANADIANOLDS's Avatar
how does coating fix poorly machined gears?
Old Mar 22, 2026 | 01:40 PM
PaulWinn's Avatar
Yes I agree. I have polished all gear edges before on a Chevy and it made all the noise go away.
Update I have the new pump in, pickup height set and checked, pan back on. Ill let the sealants cure a day. I can already tell this pump is much more quiet
Old Mar 22, 2026 | 04:39 PM
cutlassefi's Avatar
They’ll wear in and the coating will fill most if not all of the valleys of the chatter marks. I’ve done it dozens of times, it helps.
Old Mar 23, 2026 | 07:32 AM
so coating helps them wear…. gotcha
Old Mar 23, 2026 | 10:09 AM
cutlassefi's Avatar
Wrong, but stick with that if you like.
Old Mar 23, 2026 | 12:32 PM
it was you who said the coating wears them in.
coatings do not fix poor machining
Old Mar 23, 2026 | 01:01 PM
Run to Rund's Avatar
Having the pump pickup resting on the pan probably telegraphed the noise and make it seem a lot worse. I have also run into the opposite situation, where the supposedly correct bolt-on pickup was not close enough to the bottom of the pan.
Old Mar 23, 2026 | 01:26 PM
cutlassefi's Avatar
Correct, it’s a band aid at best.
But ALL my pumps with coated gears actually increase in pressure after they’ve been run for a while. To me that tells me the gears are wearing in and there are less voids between the peaks and valleys.
Pressure stays constant from there, that’s all I need to see.
Old Mar 23, 2026 | 06:07 PM
  #31
PaulWinn's Avatar
Engine is priming very well with the new pump. Sooo much smoother and quieter. All good to drop the motor in now
Old Mar 24, 2026 | 10:57 AM
  #32
Bernhard's Avatar
Mark
Are you having the oil pump gears rem finished / micro polished prior to coating?
Old Mar 24, 2026 | 01:47 PM
  #33
cutlassefi's Avatar
Originally Posted by Bernhard
Mark
No, just coated.
Old Mar 24, 2026 | 04:57 PM
  #34
JMJ-RIP's Avatar
My original oil pump driveshaft didn't have that clip (circled in yellow). The new one I bought does.
#1 - Do I leave it on or take it off (have they ever fallen off) ?
#2 - If leaving it on, does it go on top (toward the distributor), or the bottom (oil pump end)?
#3 - What's its function? (since it wasn't original, on this car).
Old Mar 24, 2026 | 05:24 PM
  #35
PaulWinn's Avatar
Shaft installs up from the bottom with the clip near the bottom. (It won't go the other way). Keeps you from pulling the shaft out with the distributor
Old Mar 25, 2026 | 01:07 AM
  #36
GCH's Avatar
GCH
This is is a pic of my engine when oilpump and distributor still was mounted.
Old Mar 25, 2026 | 03:47 PM
  #37
JMJ-RIP's Avatar
Thank you.
Well that's not going to work, I was a bit slow on this question. The oil-pump and pan is all buttoned up.
I suppose I will either cut that retainer off the new shaft or I could use the old one. My first choice is to remove that retainer. #!&%*$
Old Mar 26, 2026 | 01:29 PM
  #38
The clip isnt needed. Its only purpose was to prevent the driveshaft from falling out of the engine while it was moving down the assembly line. Kinda like the clips they put over the wheel studs
Old Mar 26, 2026 | 02:00 PM
  #39
v8al's Avatar
PaulWinn
Apr 8, 2024 02:02 PM
Chuxter
Dec 19, 2023 07:35 PM
jskorz
Oct 9, 2021 12:55 PM
David DeCan
Jan 15, 2016 07:05 PM
Jolly Green
Jul 24, 2013 12:16 PM
