1970 442 question - threaded hole in intake
Old Mar 6, 2026 | 06:31 AM
PaulWinn's Avatar
What goes here? The SAE threaded hole is not pipe threads but the bolt hole goes through the casting into the intake.
Old Mar 6, 2026 | 06:51 AM
VC455's Avatar
Barely Registered
That's the location for devices that control throttle position. Which device belongs there changes depending on the year model and the options on your car.
For example, if you car has cruise control, the throttle actuator goes there.
Old Mar 6, 2026 | 07:04 AM
tru-blue 442's Avatar
Old School Olds
That's the spot for the dashpot bracket on a 70 with a/c.
Old Mar 6, 2026 | 07:43 AM
It's a bracket for the throttle dashpot.
Old Mar 6, 2026 | 07:50 AM
PaulWinn's Avatar
Ok - my car does have AC - where can I source the correct parts? Mine are missing
Old Mar 6, 2026 | 10:16 AM
VC455's Avatar
Barely Registered
Paul, being concerned with originality, look into why your engine has the wrong oil filler cap for 1970. It should be the AC FC-60. (I grabbed this image which shows the correct look but that chrome finish and rivet indent style were not used on OEM caps.)
1969 Oldsmobile Cutlass/442/F85 CUTLASS 442 ENGINE OIL FILL CAP AC-FC60 CORRECT - NEW CHROME OIL FILL CAP AC-FC60. USED ON ALL 1968-70 OLDSMOBILES WITH 350 400 OR 455 ENGINES. AC-FC60 IS STAMPED ON THE CAP ALONG WITH ENGINE OIL FILL | EN10965T
Also check your engine's VIN derivative code because a serif "F" indicator does not rule out the block being made later than the 1970 model year.
Old Mar 6, 2026 | 10:26 AM
70Post's Avatar
Repro dashpot brackets are available....here's one of them...
https://www.inlinetube.com/products/...T2RtHPzFcKxVrU
As far as the dashpot itself....there are various versions out there in the aftermarket parts business....none are EXACTLY correct to original (I believe) but may suffice. You'll have to do a search. Or you may be able to find good used originals or NOS (big $).
Old Mar 6, 2026 | 11:40 AM
PaulWinn's Avatar
Thanks to all.
The block is original and numbers match. This is a Z code assembled in Fremont. Seems like every other 70 is an M. Has the odd scattered out VIN plate
Old Mar 6, 2026 | 11:43 AM
Originally Posted by PaulWinn
Thanks to all.
Fremont built plenty of 442s.
Old Mar 6, 2026 | 01:29 PM
Is that a 442 and/or 455 thing? My 1970 350 has the style cap in the OP's picture.
Old Mar 6, 2026 | 02:21 PM
v8al's Avatar
Registered Olds Owner
Here's a picture of it installed:
https://classicoldsmobile.com/forums...3/#post1430987
Old Mar 6, 2026 | 06:17 PM
PaulWinn's Avatar
Curious what operates it? Vacuum or electrical
Old Mar 6, 2026 | 07:09 PM
Neither vacuum nor electrical - it is not actively controlled.
https://classicoldsmobile.com/forums...st#post1430987
Old Mar 6, 2026 | 07:11 PM
As explained (by Joe) in the link I posted (above) ^^
That particular dashpot isn't actively controlled. It's just a spring-loaded plunger with a diaphragm. It has no idea if the A/C is on or off. All it knows is that when the throttle arm on the carb hits it, the spring compresses, the plunger moves, and the diaphragm slows that process.
Old Mar 6, 2026 | 07:30 PM
Anticipating your next question might be an adjustment for fitting this dashpot. I'll save you the time hunting...
Old Mar 7, 2026 | 04:06 AM
PaulWinn's Avatar
Thanks much to all.
I found a dashpot, looking for the bracket - would prefer an original - anybody happen to have one I could buy?
Old Mar 7, 2026 | 05:36 AM
1968-72 Oldsmobile Cutlass Dash Pot Bracket 1pc
Old Mar 7, 2026 | 06:44 PM
442crzy's Avatar
I have an original bracket, PM sent
bear442
Dec 28, 2020 07:23 PM
WhiteRockH/O
Dec 19, 2017 08:39 AM
jesseb
May 21, 2013 06:51 PM
AZ442
Sep 24, 2010 12:39 PM
The Stickman
Nov 16, 2009 08:52 AM
