How to tell compression
Old Oct 26, 2025 | 05:21 PM
79cut's Avatar
I’m not sure if you can tell what my engine compression is for these build sheets
but if you hear heads can please let me know
I’m just curious on what it is
Old Oct 27, 2025 | 01:50 AM
JerryW's Avatar
There is no information about your cylinder heads. What are you using for heads?
Old Oct 27, 2025 | 03:02 AM
79cut's Avatar
I believe they are the stock heads
the block is a 1976 455
Old Oct 27, 2025 | 03:16 AM
JerryW's Avatar
You didn't provide all the info, but let's assume the following. The pistons are advertised at 18cc dish. What head gasket? I'll assume a FelPro that's 0.039" thick and 4.2" in diameter. The heads, assuming they are untouched, should be 80cc chambers. So all of the previous would give you about 9.7:1.
jerry
Old Oct 27, 2025 | 09:38 AM
cutlassefi's Avatar
Actually you’ll have closer to 9.25:1.
A ‘76 will have J heads, which are normally 84-85cc
Next, that piston is short so you’ll have at least .030 deck clearance. Add the gasket and you’ll be much closer to 9.25:1.
Old Oct 27, 2025 | 09:44 AM
JerryW's Avatar
The engine builder provided deck clearance of less than 0.010" on each cylinder. My original estimate took the deck clearance he provided into account and a 0.039" think head gasket. If the heads are 85cc and not 80, then compression ratio would go from 9.7 to 9.3:1.
jerry
Old Oct 27, 2025 | 10:07 AM
cutlassefi's Avatar
I didn’t see the .010 deck, sorry.
2blu442
Aug 12, 2023 08:06 PM
Nlann
Nov 24, 2022 06:53 PM
Koda
Mar 15, 2022 08:12 AM
65-330
Dec 21, 2021 03:41 AM
FinOldsMan
Aug 17, 2013 07:02 AM
