1970 455 pistons ?
Good possibility. Most aftermarket pistons have numbers in the top. Do you have the oil pan off ? look and see if there are numbers on the inside of the pistons.
That being said, the engine has obviously been worked on before. Those are not stock head gaskets and the block has been decked. Can you measure the bore size ?
^^^^^^^, agreed. IF it is a ‘70 block, it’s been in to, as mentioned.
The reason to know is that this one is usable as is, but may need my ported #6 heads (and my one set of shim gaskets) with large valves (2.07/1.71) and bbo intake ports to allow it a small cam. 98% Street use and abuse only! (68 sports coupe, auto, 3.31 gears).
Nov 1, 2020 07:33 PM
