1970 455 pistons ?
Old Sep 16, 2025 | 02:22 PM
67cutlass67's Avatar
1970 455 pistons ?
I just pulled apart my 1970 455 motor.
Do these look like the stock pistons for this motor? Thanks in advance for any help.
Old Sep 17, 2025 | 03:59 AM
BillK's Avatar
Good possibility. Most aftermarket pistons have numbers in the top. Do you have the oil pan off ? look and see if there are numbers on the inside of the pistons.
That being said, the engine has obviously been worked on before. Those are not stock head gaskets and the block has been decked. Can you measure the bore size ?
Old Sep 17, 2025 | 06:01 AM
The semi-circular notch and the soup bowl-sized dish in the piston show these to be factory cast low-compression pistons. Are you sure this is a 1970 short block? Checked the VIN derivative stamp?
Old Sep 17, 2025 | 03:08 PM
cutlassefi's Avatar
^^^^^^^, agreed. IF it is a ‘70 block, it’s been in to, as mentioned.
Old Sep 17, 2025 | 10:24 PM
Old Sep 18, 2025 | 06:23 AM
Originally Posted by 67cutlass67
The "9" shows this to be a 1969 model year block and the "X" shows this to be from the Fairfax, KS assembly plant, which only built full size cars in the 1969 model year. This short block is from a 1969 low compression 2bbl motor that was born in a Delta 88.
Old Sep 18, 2025 | 09:51 AM
68post's Avatar
I have an exact version of this engine ('69 455 2bbl), and I know it's factory compression ratio rating was 9.0-1 with a OEM gasket. What was it's actual compression (I guessed 8.7, and that it's better slightly than an 8.5 rated later model)?
The reason to know is that this one is usable as is, but may need my ported #6 heads (and my one set of shim gaskets) with large valves (2.07/1.71) and bbo intake ports to allow it a small cam. 98% Street use and abuse only! (68 sports coupe, auto, 3.31 gears).
Old Sep 18, 2025 | 02:10 PM
Thanks for all the answers guys. That’s just what I needed to know. Definitely appreciated.
wr1970
Nov 21, 2023 09:02 PM
deadeyejedi
Mar 12, 2023 09:17 AM
Nov 1, 2020 07:33 PM
oldguy442
Oct 19, 2020 10:39 AM
Cosmic Charlie
Feb 4, 2020 03:32 PM
