71 442 Fuel issues
Old Aug 11, 2025 | 02:51 PM
Mu37strd's Avatar
71 442 Fuel issues
I have an all original 71 442 that has been giving me some issues. It will run great for a while and then it starts acting like it’s starving for fuel. As soon as I try to give it gas it falls on its face. I rebuilt the carb thinking that was the issue but no change. I also replaced the fuel pump just to rule that out but again no change. I figured there must be some junk in the tank that was gutting sucked into the pickup intermittently but I dropped the tank and it looks brand new inside. The sock on the pickup is black/brownish and brittle. Could that be my issue? I have included a picture of the sock and the inside of the tank.
Old Aug 11, 2025 | 03:43 PM
dc2x4drvr's Avatar
Replace the sock.
Old Aug 11, 2025 | 03:46 PM
Tri-Carb's Avatar
Have you checked to see if the tank is venting?
Old Aug 11, 2025 | 03:56 PM
Mu37strd's Avatar
I have not checked to see if it is venting. What’s the best way to check?
Old Aug 11, 2025 | 04:02 PM
Tri-Carb's Avatar
If I had it apart like you show, I would blow some air down the vent lines with an air compressor and listen in the sending unit opening.
Old Aug 11, 2025 | 04:14 PM
Mu37strd's Avatar
Are all three of the lines on the front of the tank vent lines?
Old Aug 11, 2025 | 04:18 PM
Mu37strd's Avatar
Here is a pic of the whole tank
Old Aug 12, 2025 | 05:06 AM
jaunty75's Avatar
Have you checked/replaced the fuel filter?
Since you've taken the tank down, why not just replace the entire sending unit, which will include a new sock?
Old Aug 14, 2025 | 08:11 AM
Mu37strd's Avatar
Yes, the filter was the first thing I tried. I will just replace the whole sending unit while it’s apart.
Old Aug 16, 2025 | 04:37 AM
shiftbyear's Avatar
Also check the rubber fuel line connections along the frame. If they're dry rotted they may suck air.
Furbody
Jul 22, 2025 08:50 AM
7098olds
Oct 2, 2023 08:46 AM
Ttnc
Mar 28, 2021 06:16 AM
pinky3034
Jun 28, 2011 08:42 AM
nohn
Sep 25, 2008 12:44 AM
